Flip Stop
jimthej
Flip Stop
Post by jimthej »
Just finished a planter box. Needed a bunch of fairly short cuts in bunches of 4 or more(up to 16 of one size). Looked around for something to clamp to the fence to use as a spacer block to measure by. Saw one of my Flip Stops on the shelf and grabbed it. I hooked it onto the top of the 520 fence. After I set the magnetic steel rule correctly, I could move the stop over the steel rule to set the fence. Move it down to the blade to verify against a close tooth. Then set it about right for hitting the wood as I scooted it up the fence of the crosscut table. Just had to flip it up to do the ripping.
Jim in Bakersfield:D
fixit
Post by fixit »
Forgive me for being dense but... ??????????????????????????! Maybe a picture or two would help my pea brain to understand what you said.:o
Leonard
La Vernia, TX
Wood Goods - Custom Woodwork
a1gutterman
Post by a1gutterman »
fixit wrote:Forgive me for being dense but... ??????????????????????????! Maybe a picture or two would help my pea brain to understand what you said.:o
Hi Leonard,
Try looking here for the 505/510 (and some 500's) and here for the 520. :)
Tim
a1gutterman wrote:Hi Leonard,
OK. Now I understand what a flip stop look likes but I'm with Leonard. Explain to me the ripping process that jimthej has going on..
