Greenie Parts replacement help
Post by 2106 »
Hello, my first post on the forum.
I have acquired a 1956 Shopsmith which I believe is known as a greenie. It was in rough condition. I hate to see good things thrown in the landfill when they still have life left in them. This machine seems well built. The parts are stamped USA. Hard to find good old solid AMERICAN craftsmanship today, no matter what the cost. I have completely disassembled the unit including the headstock. There is a small collar plastic piece which acts as some type of bushing between the male and female spline shafts and slides into the quill. Shopsmith listed only one type headstock unit for all models in their parts section. I saw the part I needed was available, so I ordered this part number #514083 ring assembly. While awaiting for the part I invested many hours in continuing the restoration, painting, and belts. The ring assembly arrived and is massive and doesn't fit. It is way too large and the gear teeth molded into the plastic don't fit the teeth on the spline. I have a one bearing quill and all bearings are quiet and smooth. I contacted Shopsmith who said sorry but we will sell you a upgraded two bearing quill for $400. I need a $5 plastic ring, I can buy a complete used newer shopsmith all the time for less than $500.
I know someone with a 3D printer. Can I get the specs or something so I can get one made? The old plastic collar is small, thin, and in pieces it was totally disintegrated, maybe from age. Can some other part from something fit that I can get from the internet be modified? I'm sure a machine shop could make something but that would be quite expensive.
Anyone have a old part that they would sell?
Can anyone offer me any advice or suggestions?
Thanks
edma194
Re: Greenie Parts replacement help
Post by edma194 »
Post some pictures of the parts so we can accurately identify them. Used parts are available and you don't need the exact main spindle configuration the machine had originally.
DLB
Post by DLB »
I made the same mistake on this same part about 40 years ago. ;) It wasn't available then either and I have never seen them for sale. It is not strictly necessary for the headstock to run, I ran mine for decades without one. Unlike the part you acquired, the older Gilmer headstocks have a metal to metal drive for the quill spindle. I believe the purpose of the part is to reduce the noise coming from that metal to metal drive. Mine was never in usable condition, so I don't have first hand experience with that. If my understanding of its purpose is correct, I believe a replacement needs to have two different IDs, a very snug fit over the outside of the drive sleeve and a looser fit over the splines, which need to slide axially as the quill extends.
I believe the only part Shopsmith has ever carried that is unique to the Gilmer drive machines is the belt itself.
The part is essentially a dust cap only. As for noise reduction, a thick layer of grease accomplishes that. That grease is the reason for a dust cap.
Yes I think one could be 3d printed. David provided the necessary design goals.
As has already been said the plastic cap on the end of the Drive Sleeve shown below is not necessary for the Mark 5 Gilmer Drive system to function. The first mark 5 Greenies made did not have the plastic cap.
_
Gilmer Clutch Type Drive Sleeve.jpg (52.22 KiB) Viewed 3542 times
If you desire to keep your Mark 5 Greenie original, great. Some owners have chosen to upgrade their early Mark 5 (all Greenies and early Goldies) from the Gilmer Drive to the Poly V Drive. That is where all those costs come in. You have to replace the Idler Shaft Sheeve, Drive Sleeve Assembly and the Quill Assembly plus a belt.
MechaNickW
Post by MechaNickW »
Hello! I actually designed and 3D printed one of these fittings when restoring my Greening from 1955. This link will allow you to download a file for your friend to 3D print: https://www.thingiverse.com/thing:1990694
Glad to see this get some use by anyone doing restorations on these amazing machines. All the best!
Think Dust Cap.
rodrigueza,
As JPG said, "Think Dust Cap", which is a good description and was added later in the production of the Mark 5 in the 1950's. It's actual function, if I recall correctly, was to reduce noise. As said previously it is not needed for the Mark 5 to function correctly. It can help keep dust out of the splines inside the Drive Sleeve Assembly.
Just a reminder for anyone reading these threads, when looking for replacement parts the current parts found here on the Shopsmith Website are for the current machines. There have been many changes made over the years since the Mark 5 was first introduced in 1954. A lot of those changes have occurred in the Headstock. One of the biggest changes in the Headstock occurred in 1961 going from the Gilmer Drive to the Poly V Drive. The Poly V Drive is still in use today in Conventional Headstocks. Changing from the Gilmer Drive to the Poly V Drive requires changing to the Poly V Idler Sheave, the Drive Sleeve Assembly, the Quill and the upper Belt. Many owners have made that change. Just prior to the change to the Poly V Drive was the change from the 3/4 HP Motor to the 1-1/8 HP Motor. The Motor can be done without other changes needed.
Anyone working on a Mark 5 Greenie or early Goldie is advised to ask questions here about what current parts can be used and what parts cannot. Mid 1961 Goldie Mark 5/V's and later have the 1-1/8 HP Motor and the Poly V Drive as they came from the factory.
