Mark V replacement pinion gears
Mountainroads
Post by Mountainroads »
I’ve been using my mark five for a bit but the table gears never worked so I finally took it apart to see that the pinion gears are stripped and broken. And I’ve been looking for replacements but have had no luck online so I was wondering if anyone else had any idea where I could get some?
Re: Mark V replacement pinion gears
Mountainroads,
There are two versions of those gears. The ones JPG provided the link to from here on the Shopsmith website are the Carriage Pinion (for MARK 7/MARK V 520,510,505/MARK 4) part number 514211 and are not for the Mark 5 or Mark V500 with the original Table System. Those for the Mark 5/V 500 would be part number 501392 and are no longer available new from the factory. If yours are like the ones below (also damaged) they are for the Mark 5/V 500 and they would have to be found used.
_
If yours look like the one below for the Mark V 510/505, 520, Mark 7 or Mark 4 order them from Shopsmith.
_
Carriage Pinion PN 514221.jpg (8.63 KiB) Viewed 29333 times
There are two different Carriages used for the different Mark V models and two different Carriage Pinions.
Learned something for today!
JPG,
I still learn things from you and others here and it is what I love about this Forum.
Mountainroads,
I hope this information is helpful for you to get the correct Carriage Pinion for your Mark V. I had a Mark V I restored with the Pinions shown in my last post.
For anyone I like to warn against is using the Main Table as a work bench especially "hammering" thing on it. It is likely what happened to your Mark V before you got it.
If you have any other questions about your Shopsmith feel free to ask.
