Level Way tubes(A)
Level Way tubes(A)
This thread shows a method of reassembling the way tubes and adjusting them to be level.
BASE REASM LEV BCH.jpg (280.48 KiB) Viewed 4799 times
Level the bench tubes (both ends). This establishes a reference for adjusting the way tube stop. Shim the tubes if necessary.
BASE REASM TIE.jpg (408.08 KiB) Viewed 4788 times
Notice the stop for the way tubes in the tie bar. Insert the tie bar over both waytubes all the way to the stop. Do Not tighten the set screws at this time.
BASE REASM LEV ADJ.jpg (239.17 KiB) Viewed 4794 times
This shows the way tube leveling screw. You must access it from below while watching a level on the top(next thread).
BASE REASM OLD ADJ.jpg (231.54 KiB) Viewed 4794 times
This pix shows the screw on an older mark 5.
Thanks to judaspre1982 for the following: Even older Mark 5's(pre 1955) did NOT have the adjusting screw and required you to file the casting!
This thread is one of several which illustrate a method for reassembling a Mark V. Please post a reply and inform me of any errors or confusion. They WILL be fixed!
This thread was linked to from https://forum.shopsmith.com/viewtopic.php?t=3807
judaspre1982
Post by judaspre1982 »
keakap
Post by keakap »
JPG40504 wrote:This thread shows a method of reassembling the way tubes and adjusting them to be level.
holy moly-- I shouldn't have looked at these pictures in the thread in one sitting. Up, down, horizontal, partial pics, upside down, from the top,,,
man, I need to go ride a roller coaster to get my equilibrium back to normal.
Dizzy City!
