This thread is intended to illustrate the reassembly of a MarkV Base and Carriage.
Notice the use of 'horses' to raise and support the 'work underway'. This allows rotating the entire frame so as to better 'get at' those things normally difficult because they are 'underneath'. Keep this in mind when viewing the pix. Many are viewpoints you are not accustomed to seeing! The legs are intentionally left until nearly last for this reason.
Base Reassembly(A) Bench Tubes http://www.shopsmith.net/forums/showthr ... #post41342
Base Reassembly(B) Way Tubes https://forum.shopsmith.com/viewtopic.php?t=3818
Base Reassembly(C) Hinge Pin http://www.shopsmith.net/forums/showthr ... #post41466
Carriage Reassembly(A) http://www.shopsmith.net/forums/showthr ... #post41467
Carriage Reassembly(B) http://www.shopsmith.net/forums/showthr ... #post41468
Level Way tubes(A) https://forum.shopsmith.com/viewtopic.php?t=3823
Level Way tubes(B) http://www.shopsmith.net/forums/showthr ... #post41477
SPT Clamps http://www.shopsmith.net/forums/showthr ... #post41481
Reattaching Legs http://www.shopsmith.net/forums/showthr ... #post41541
This thread is currently being created. Please be patient!
This thread is one of several which illustrate a method of reassembling a Mark V. http://www.shopsmith.net/forums/showthr ... #post41339
Any errors or confusion of which I become aware of WILL be 'fixed'. I solicit input regarding them.
Reassembling the Base and Carriage
Base and Carriage Reassembly
Re: Reassembling the Base and Carriage
I have corrected the links from JPG's post above here.
Base Reassembly(A) Bench Tubes viewtopic.php?p=41342#post41342
Base Reassembly(B) Way Tubes viewtopic.php?t=3818
Base Reassembly(C) Hinge Pin viewtopic.php?p=41466#post41466
Carriage Reassembly(A) viewtopic.php?p=41467#post41467
Carriage Reassembly(B) viewtopic.php?p=41468#post41468
Level Way tubes(A) viewtopic.php?t=3823
Level Way tubes(B) viewtopic.php?p=41477#post41477
SPT Clamps viewtopic.php?p=41481#post41481
Reattaching Legs viewtopic.php?p=41541#post41541
Unfortunately, there is missing information/pictures in some of the threads.
