Power Stand Parts
bhurley
Power Stand Parts
I can't seem to locate a parts listing for the power stand. I need to find the removable safety key and the v-belt ( or the length of the belt so I can purchase locally ). Does anyone have a clue where I should look?
- RobertTaylor
power stand
the safety key is part #513411 and currently $4.52. the length of the belt could be determined by measuring with a tape around the pulleys. you id not say what tool you are putting on the stand and i'm not sure if all spt's use the same belt. ie: different pulley sizes. the length may not change that much bit i don't know for sure. i made my own replacement keys from a piece of 1/4" dowel with a short piece of 1/8" dowel and a piece of a popcicle stick for the handle.
A picture or pictures of the replacement key would be GREAT!
Leonard
La Vernia, TX
Wood Goods - Custom Woodwork
Leonard
La Vernia, TX
- RobertTaylor
ok, here is a pic of my "replacement saftey key" and for what it's worth the belts on my proplaner and bandsaw are both 38 inches long by 1/2" wide.
- IMG_7330 (Small).JPG (17.96 KiB) Viewed 8301 times
Thanks for giving me a "Now why didn't I think of that?" moment!
Leonard
La Vernia, TX
Leonard
La Vernia, TX
Power Stand Parts
I like to use 1/2" link (Power-Twist) belts as they can be made for what length you want. I normally buy the 4' or 5' link belts and assemble it to the length I need. It is very quick to add or remove a link once the belt tension is checked.bhurley wrote:I can't seem to locate a parts listing for the power stand. I need to find the removable safety key and the v-belt ( or the length of the belt so I can purchase locally ). Does anyone have a clue where I should look?
