Removing paint spatter?
ddresser
Post by ddresser »
Recently aquired scroll saw that has paint spatter on it. Any ideas on a way to clean it off?
[ATTACH]5350[/ATTACH]
[ATTACH]5351[/ATTACH]
Thanks,
Duane
bucksaw
Post by bucksaw »
Some suggestions on this site might work. Stop by a paint shop and see it they have any suggestions.
Rubbing alcohol (3% isopropyl alcohol from grocery store) may work.
http://homeimprovement.lovetoknow.com/R ... wood_Floor
Dave - Idaho
"Why do we drive on parkways and park on driveways?" :cool:
bucksaw wrote:Some suggestions on this site might work. Stop by a paint shop and see it they have any suggestions.
[93%] might work better!:D IF latex base. If oil base, something stronger. Mineral spirits and elbow grease. Any thing stronger may also remove the 'original' finish. Try goo-gone!
robinson46176
Post by robinson46176 »
I would probably try mineral spirits first.
Next would probably be some kind of rubbing compound, maybe automotive just because I have a good bit of it on hand.
You could also try Pumice or rotten-stone.
Another option and one I am good at is to just ignore it. :D
a1gutterman
Post by a1gutterman »
I am with the farmer; what paint spatter??? More to my interest is that your scroll saw is Made In The USA! :D
Tim
ddresser
Post by ddresser »
Thanks for the suggestions. Paint store had something called Oops to remove dried latex. That got most of it off and if I don't look thru the bottom of my bifocals can't see the rest.
Thanks again,
Duane
ddresser wrote:Thanks for the suggestions. Paint store had something called Oops to remove dried latex. That got most of it off and if I don't look thru the bottom of my bifocals can't see the rest.
Thanks again,
Duane
Wonder what the main ingredient is????
