How to make a Shopsmith bandsaw wooden stand
dalycity
Post by dalycity »
Hello, dear woodworkers!
Does anyone know how to make a wooden stand for my Shopsmith bandsaw? I cannot figure out how to mount the bandsaw on a piece of wood. I think I will need to drill two holes to allow the mounting tubes to go through the top board.
Any suggestions would be very helpful.
Thanks!
dalycity wrote:Hello, dear woodworkers!
Thanks!
If I was doing what I believe you are, I'd use this:
http://www.shopsmith.com/ownersite/cata ... ngbase.htm
The picture shows a Strip Sander but these work on all of the SPT.
a1gutterman
Post by a1gutterman »
Thanks!
You wood need to drill holes in a block of wood thick enough to keep it from tipping, and then mount the block of wood to a table or a set of legs so it wood not tip over.
Tim
greitz
Post by greitz »
Don't the mounting tubes need to be firmly bolted to something to reduce vibration? I had a bad vibration problem with the bandsaw once, and traced it down to the mounting tube locking mechanism being mis-adjusted and tightening on only one tube, instead of both of them.
Gary
robinson46176
Post by robinson46176 »
dusty wrote:If I was doing what I believe you are, I'd use this:
Or... go to your stash of Shopsmith stuff and take an extra end mount down off of the shelf and use that. :D
Then you would have the locking mechanism too.
a1gutterman
greitz wrote:Don't the mounting tubes need to be firmly bolted to something to reduce vibration? I had a bad vibration problem with the bandsaw once, and traced it down to the mounting tube locking mechanism being mis-adjusted and tightening on only one tube, instead of both of them.
Gary
Oh! My suggestion was for storage, knot for using!
Tim
greitz
Post by greitz »
Maybe it was my mis-reading the question- I just assumed we were talking about making a home-made power station for the bandsaw. I should know by now not to assume!
Gary
