Finding the center of a circle
- mickyd
reible posted a pretty classy way to find the center of a circle using a gorgeous brass Wood Lathe Center Finder.
Here's a much less classy (aka cheap) most of the time "close enough" version is you don't have anything as spectacular.
[ATTACH]6281[/ATTACH]
[ATTACH]6282[/ATTACH]
[ATTACH]6283[/ATTACH]
[ATTACH]6284[/ATTACH]
Where the lines bisect is .........the center.
- a2mod.jpg (52.88 KiB) Viewed 5704 times
- a3mod.jpg (48.74 KiB) Viewed 5715 times
- a4mod.jpg (57.25 KiB) Viewed 5707 times
- a6mod.jpg (51.05 KiB) Viewed 5702 times
Sunny San Diego
Sunny San Diego
- curiousgeorge
- mickyd
curiousgeorge wrote:Thanks, Mike. That is simple, easy to remember and a lot cheaper than having to buy a center finder.
Then there is the good old "eyeball" method. No photos needed to demonstrate that!!
Sunny San Diego
Sunny San Diego
My experience is this method works better with larger circles, and with smaller ones it doesn't matter as much anyway.mickyd wrote:Then there is the good old "eyeball" method. No photos needed to demonstrate that!!I think I'll just have to try that vs. the geometry method above just to see how close I can get.
You folks are far classier than I am. I just measure across the widest point of the circle with my tape measure that once you read the width shows the center or 1/2 way point for that particular length. fjimp
F. Jim Parks
Lakewood, Colorado:)
- Ed in Tampa
It depends on what I want the center for. If I need to be real precise I use a compass set to a radius that is larger than the circle. I make two marks on the circle and then move the compass to make two more marks. I connect the first set of marks where they touch the circle and then the second set. Where these lines cross is the exact center of the circle.
Ed in Tampa
Stay out of trouble!
rdewinter wrote:I wish I would have known how my geometry studies could come in handy some day. It's sad that I forgot (or maybe I didn't study hard enough) so much of my mathematics. Thanks for the great tip Mike.
San Diego
That is so true and I think universally applicable. If only my geometry and algebra teachers had known how to show me that this stuff was going to help me to do something other than graduate.
I refer to a high school math book probably once a week (at least).
- mickyd
Is that school book on a papyrus scroll or carved in stone? I am not sure what the technology was back in those daysdusty wrote:That is so true and I think universally applicable. If only my geometry and algebra teachers had known how to show me that this stuff was going to help me to do something other than graduate.
Sunny San Diego
Sunny San Diego
mickyd wrote:Is that school book on a papyrus scroll or carved in stone? I am not sure what the technology was back in those days. (sorry dusty...I just couldn't resist!!)
Maybe mike should run over to Bob's place and tutor him(refresh his math memories)!:p
BTW This older than Dusty person does NOT recall any of those ancient objects in HIS school days except in books of a historical bent. We didn't use wax tablets and stylus either!:rolleyes:
