Dust collector hoses
robinson46176
Post by robinson46176 »
I have been intending to post this for a while now but keep forgetting.
My shop configuration type (spread out and sloppy) means that I spend a lot of time stepping over dust collector hoses. I often find that I don't really need to run a full 4" hose to each tool. For some things like a scroll saw a very small hose works. On the other hand my oscillating belt sander could use a 12" hose. :D
I have collected vac hoses for some time since we were in that business for a long time but many of the long vac hoses i collected then are now aging out. Many vac hoses are pretty $$$. I have found several good low cost substitutes. One is swimming pool filter and skimmer hoses, many of which are being clearanced out as I speak. For something like a scroll saw etc. you can buy light weight sump pump hoses for very little cost. I just bought a big long 20' one at a yard sale for .50¢ still in the new packaging.
I actually like the light weight plastic hoses much better than the heavier vac hoses. Connections are easy with the magic of duct tape :) or you can use commercial fittings.
chucks
Post by chucks »
robinson46176 wrote:the heavier vac hoses. Connections are easy with the magic of duct tape :) or you can use commercial fittings.
I went scavenger hunting for hoses like that last week....starting at our local woodworking stores. Couldn't find anything, than my wife thought of that very solution. So we now have 1 hose and will be trying it soon. We're still setting everything up and with 2 Dc3300's, economical sounded pretty good.
Chucks in Phoenix Mark V(5), Mark VII(2),Power Pro, Planer, Crafter Station, Jointer,Bandsaw(3),Lathe Duplicator,Belt Sander,Jig Saw,DC3300(2),"Sears Router Crafter", Post Drill, Stand alone Overarm Router. Jointmatic ++++,
