Wayward set screw
wdelliott
Wayward set screw
Post by wdelliott »
I was turning some chisel handles yesterday when a set screw fell the shop floor. I have no idea where it came from and have looked all over my SS. The lathe equipment, including the tool rest, was and is solidly in place, so it must not have come from the lathe or the tool rest.
If anyone has a thought, I would welcome it. I restored a 1963 XKE Jaguar in my youth, and when finished, I had a box of screws, bolts, nuts, etc. left over. I always wondered where all of those parts went. As I would drive that wonderful car, I expected something to fall off. I thought of that experience was with me yesterday.
I just do not understand where there is a set screw and why it would have come out.
Wm. D. Elliott
Dallas, TX
1972 Model 500; upgraded to Model 7; bandsaw; belt sander; joiner; planer pro; power stand; OPR; Biscuit joiner; router tables
wdelliott wrote:I was turning some chisel handles yesterday when a set screw fell the shop floor. I have no idea where it came from and have looked all over my SS. The lathe equipment, including the tool rest, was and is solidly in place, so it must not have come from the lathe or the tool rest.
Maybe this will help. This is a compilation of information taken from the Shopsmith Parts Lists.
PS Sorry for the poor quality. I had trouble converting the file format and this is the best that I have gotten, so far.
[ATTACH]6487[/ATTACH]
Shopsmith Setscrews Version 4.jpg (81.35 KiB) Viewed 5995 times
Which 'end' did it 'fall' from? If the tailstock end, I would look to see if the way tube set screws are Both still there. They are not only difficult to see, but also difficult to access and tighten.
[ATTACH]6490[/ATTACH]
The pix shows a bench tube in the lower right corner and the way tubes raised into vertical position in the upper left corner.
There is a set screw holding each way tube back under the 'hinge pin'.
BASE REASM HINGE PROBLEM.jpg (299.39 KiB) Viewed 5985 times
greitz
Post by greitz »
Are you using the Universal Tool Rest? On mine, on the upper portion which holds the tool rest itself, I have an extra set screw along with the locking handle. It was there when I assembled the UTR, and I've never taken it out. It does get loose from vibration occasionally, so I just finger-tighten it and forget about it.
Gary
fjimp
Post by fjimp »
Every time a set screw or bolt falls out of a piece of equipment in my shop I find the source one day. Usually when it creates a needless bit of destruction. Always discovering it belongs to a different tool than I ever dreamed it could be related to. jim
F. Jim Parks
Lakewood, Colorado:)
William
Can you identify the setscrew in terms of length and type of point?
I know that you were turning but were any of the accessories mounted so that they could be the source?
