I recently purchased a refurbished Power Station from Shopsmith. Which, I am extremely pleased with.
But, every time I move an SPT from the Headstock to the Power Station, I have to realign the hubs. This doesn't take long. But, has anyone been able to adjust either the Headstock or the Power Station to a point where the SPT can be moved between the two without adjustment?
Thanks in advance for any advice!
Headstock/Power Station Alignment
Really need more information. Is the mis-alignment in the vertical plane or in the horizontal plane or both planes. I have made thin metal washers for the alignment between Shopsmiths. Since I never actually used a power station, I would believe some metal filing, drilling bigger holes, using shims, washers or spacers would allow interchangeability between Power Station and Shopsmith.Lodgepole wrote:I recently purchased a refurbished Power Station from Shopsmith. Which, I am extremely pleased with.
This could be why I have always recommended using a Shopsmith MINI as a power station besides it being cheaper and easiler to use.
Yes, I have a Power Station, a Crafters Station and the Mark V. I can relocate the Bandsaw to any one of them without readjustment.
What SPT are you having trouble with?
Dusty,
Thanks for your response. I graduated from the UofA 30 years ago. I can't be that old!
All of my SPTs do not line up from the Shopsmith to the Power Station. I guess I really need to spend time adjusting the Power Station.
Unfortunately, I have a rather large project I am currently working on (house remodel). So, I probably won't be able to get to this until late February.
I'll keep you updated.
I have always appreciated your advice and insight.
We'll be here if/when you have more questions. In the meantime, good luck with your remodel. Take your time and be safe.
Lodgepole wrote:Dusty,
I assume your alignment problems are front to rear(not vertical).
There are two possible causes(at the shopsmith).
The simplest is the end cap is mounted to the bench tubes slightly cocked. A similar cocking at the other end can affect this also. A similar offset can be caused if the leveling screw under the rear bench tube is incorrect.
Another possible cause (if we are considering the jointer) is the belt tension adjustment. It has an eccentric that shifts the intermediate(idler) shaft horizontally as well as vertically.
The power station slide has some slop which allows a slight vertical variance. It will only shift about 3/16" front to rear.
If you are really serious about 'solving' this, I recommend setting all spt's to the power station. It is not adjustable in any meaningful way.
Following that, adjust the shopsmith to them. I would suggest the procedure illustrated at https://forum.shopsmith.com/viewtopic.php?t=3807 . Start with the level way tubes thread.
Add a final step to align the shafts by shifting the end cap/tie rod simultaneously.
You need to be very comfortable with this procedure before starting it.
