Potpouri starting Dec 7, 2009
- mickyd
This thread is for discussing ANYTHING and rambling/changing subjects is not only allowed, but expected.
Last weeks thread was https://forum.shopsmith.com/viewtopic.php?t=4656
Sunny San Diego
Sunny San Diego
cocacola1012
http://www.dailymail.co.uk/news/article ... ungle.html
This guy makes Bear Gillis, or whatever his name is, look like a cupcake.
cocacola1012
Anybody order from this company?
http://www.woodpenpro.com/index.html
- a1gutterman
Sorry, I can knot tell you of any plans, but it has been my experience that jigs are designed and made to order by the user of the jig. A little experimenting and a lot of your time and you should be able to make something that will work.nllaeder wrote:Anyone know if there are plans available to build something similar to this jig?
I don't really cut enough miters to justify $100, but if I can make it for $20 or so, I'm all for it.
Tim
Firstly - I have been very happy with my Miter Pro! I find it to be a very quick set up to make exact 45º]any angle[/U]. It sells for around $30, but you have to order the one made to fit Shopsmiths. To learn more about MiterSet, go to the search function and type in MiterSet. You'll get 14 Threads. The oldest (bottom several) will be the most informative.
If you want to build one like a Miter Pro here's a suggestion:
- Stack (glue and screw) a couple of stable wood products like plywood.
- Saw out a PERFECT square about 3" X 3". (This will allow room between the miter slot and the saw blade)
- Mount a miter bar on the square so it runs from corner to opposite corner.
- attach two legs
Your miter bar will probably wind up a little bit off, but that shouldn't matter if your square base is exact. Cut one side of the miter on one leg of the jig and the other side of the miter on the other leg and the result will give you a square. A half º will never show.
Can't read the date Dec. 7 without thinking about Pearl Harbor!
Wow, the MiterSet is exactly what I need! Thanks a ton! I'll be asking the wife for it for Christmas.charlese wrote:Firstly - I have been very happy with my Miter Pro! I find it to be a very quick set up to make exact 45º miters. I also have a MiterSet and find it to also be very accurate for any angle. It sells for around $30, but you have to order the one made to fit Shopsmiths. To learn more about MiterSet, go to the search function and type in MiterSet. You'll get 14 Threads. The oldest (bottom several) will be the most informative.
- attach two legs
- a1gutterman
It did not go above freezing here today. Going to be in the 'teens tonight and in some places it will be single digits. I worked in that today and I get to work in that all week.
At least I get to work, unlike some that I know.
Tim
cocacola1012
Came across this while doing a search for snack tray cabinets. It is a little smaller than the one bu charlese.
http://www.amazon.com/Snack-Table-Cabin ... B000A30V10
