When I got the ER10, the table raiser crank was severly bent.
[ATTACH]7840[/ATTACH]
This was probably due to the crank getting slammed up against the arm when the ER was in the vertical drill press positon. A simple preventive measure is shown below.
[ATTACH]7841[/ATTACH]
ER modification to prevent table raiser crank damage
- mickyd
- Img_5368mod3.jpg (68.87 KiB) Viewed 6074 times
- Img_8226mod.jpg (82.73 KiB) Viewed 6095 times
Sunny San Diego
Sunny San Diego
- shipwright
Good one Mike. Mine was a little bent too. I just straightened it and didn't think any more about it. I will be making the mod. ...or maybe I'll just be careful in drill press mode but in any case it's a good observation.
Thanks
Paul M
Thanks
Paul M
Did you put a bumper on the headstock also?
- mickyd
I had mentioned that the crank handle probably got bent in drill press mode. I'm adding another possible cause. Sliding the work table / carriage over to the right and knocking it against the arm will also cause the handle to get bent. Had I not had my preventive measure in place, I probably would have bent it yesterday. I went to move the carriage and the wedge locks held on tight. When they let loose, the carriage moved VERY fast (thanks to those nicely polished, previously trashed tubesshipwright wrote:Good one Mike. Mine was a little bent too. I just straightened it and didn't think any more about it. I will be making the mod. ...or maybe I'll just be careful in drill press mode but in any case it's a good observation.
Thanks
Paul M
Sunny San Diego
Sunny San Diego
- robinson46176
mickyd wrote: and it tunked the carriage bolt / bumper pretty good.
"tunked"? Is that one of those technical engineering terms?
My stuff usually just bonks or bangs.
