Worn Quill and Drive
unclejim
Post by unclejim »
As I was trying out my new Talon Chuck my speed controller died a horrible death:( Since it has been noisier than I think it should be I decided it was time for bearings. When I got to the quill assembly I found that both the quill and drive assemblies have groves worn into the shafts, as if the dust in the grease of the quill housing were grinding the metal down.
Does anyone think this may cause problems? I wouldn’t mind changing to a 2bearing quill and the poly belt but the extra funds are not available right now.
Jim
wannabewoodworker
Post by wannabewoodworker »
I wouldn't worry about what I see in your pictures. Those look to me to be normal wear marks and nothing to get excited about. I did not see any serious grooving in either of those pictures.
Michael Mayo
Senior IT Support Engineer
Soft Designs Inc.
albiemanmike@gmail.com
1960's SS Mark VII, 1954 Greenie, 1983 Mark V, Jointer, Bandsaw, Jigsaw, Dewalt Slider, Delta Super 10, Delta 8" Grinder, Craftsman compressor, Drill Doctor, Kreg PH Jig, Bosch Jigsaw, Craftsman Router and Table...........and adding more all the time....:D
unclejim
Post by unclejim »
Thanks Michael,
That's about what I thought but wanted to run it by the group first.
Jim
wannabewoodworker
I just had mine completely apart and had the same type of striations on the shafts and it is now running like a top.
Michael Mayo
Soft Designs Inc.
