Miter gauges from pre-owned shopsmiths
I'm noticing something about the two miter gauges that came with two pre-owned shopsmiths I purchased. In both cases one of the previous owners had a little problem...
[ATTACH]9157[/ATTACH]
[ATTACH]9158[/ATTACH]
I wonder just how many times this has happened out there in the home workshops. Now I know none of you ever did this but those of you who look at / purchase pre-owned equipment how often do you see this?
dlbristol
previous owner Mitre modification
Post by dlbristol »
I knew you were going to ask this question and I know how much fun it is to see these when some one else did it, so I made one like that just so some day I can provide a laugh for some one. It is really not as hard as you might think, especially with a good SS blade.:o
Dave
With the old Mark 5 table with the 'extra' saw slot, ya kin mess up BOTH sides!:D Believe me it happens without you realizing it until too late!
[ATTACH]9159[/ATTACH]
500 miter sawing.jpg (104.96 KiB) Viewed 4787 times
easterngray
Post by easterngray »
I think the expression is "been there done that"! Alec
Gene Howe
Post by Gene Howe »
I have two miter bars for jigs, now. Expensive bars, too.
Don't ya just hate that sound when the cut off blade contacts the gauge?:eek:
Two mistakes in 30 years? Not too bad.....if those were the ONLY ones:D
Gene
kd6vpe
Post by kd6vpe »
Yep,
My brand new 24" miter guage extention like the one Nick had in his sawdust sessions one end had been nibbled off by a blade. This is the extention that you can adjust from site to side and when I did a mitre cut I did not judge the blades path very well.
PS
Aluminum does do a nice job of gleanng a blade of pitch and such when you do cut into it.;)
SS 500 upgraded to 510; SS bandsaw; SS jointer
SS Oscillating Drum Sander; Universal Lathe Rest;
lathe duplicatior, shaper fence and shapers; SS Belt
Sander
Jim
www.youtube.com/kd6vpe
[quote="kd6vpe"] . . .
PS
Aluminum does do a nice job of gleanng a blade of pitch and such when you do cut into it.]
You looked at the BLADE after doing that?:D:confused:
SDSSmith
Post by SDSSmith »
JPG40504 wrote:With the old Mark 5 table with the 'extra' saw slot, ya kin mess up BOTH sides!:D Believe me it happens without you realizing it until too late!
Wow!! I always thought the extra slot on the main table was to allow for ripping certain widths (prior to the intro of the wider extension table). Looking at the picture, it looks like the slot is used for crosscuts, crosscut bevels and dadoing in addition to ripping. It is good to continue learning something new every day.]
Rob in San Diego
SDSSmith wrote:Wow!! I always thought the extra slot on the main table was to allow for ripping certain widths (prior to the intro of the wider extension table). Looking at the picture, it looks like the slot is used for crosscuts, crosscut bevels and dadoing in addition to ripping. It is good to continue learning something new every day.]
We need an emoticon for tongue in cheek! Blinkey just doesn't quite get it!:D
Yes you CAN do those things, but just do NOT use the 'nearest miter gauge slot'!
Hey this is about 'creative' solutions to present 'problem(s)'.;)
P.S. Be careful with any 'newly acquired knowledge'. At least until full comprehension is achieved!
ryanbp01
Post by ryanbp01 »
Has anyone drilled a hole through their table insert?
BPR
