Clone Accessories
- rlkeeney
Clone Accessories
I have an accessory for my Shopsmith that is the only one I have ever seen. A Central Machinery 6 inch Jointer. I bought it from Harbor Freight around 1985 for $98 delivered. I sold some toys I made at a flea market just before Christmas to get the money to buy it. It works great and has never given me one minutes trouble. However it's a heavy sucker. Right at 100lbs.
https://goo.gl/photos/sWgFcsjkRriPnHAo6
https://goo.gl/photos/jJvDDBysrUqb1Wgu6
https://goo.gl/photos/UduiqerC3NUKe3gL6
https://goo.gl/photos/w6tbaVCCedhNped58
https://goo.gl/photos/m5ajvDHhhh11PqbE6
https://goo.gl/photos/ZGyYWJneP4qDGex39
Has anyone else seen one of these?
I also have a belt sander that isn't a Shopsmith. It doesn't have the PTO and the table only mounts one way. Its a bit tricky to get the belt aligned when the belt is new. It works and with a 60 grit belt installed it will hog some wood off. The mitre gauge slot is a a different size and came with its own.
https://goo.gl/photos/Ki3ncSrDUBZvkaea8
https://goo.gl/photos/qpChRK9CDXFEf12W6
https://goo.gl/photos/56mUKYFUZijsZcQx8
https://goo.gl/photos/HGYQCW2LRS5kR9456
https://goo.gl/photos/sGng2dvXNuP5MvkH7
Edited to fix photo links. The forum will not fetch the photos.
[quote="rlkeeney"]I have an accessory for my Shopsmith that is the only one I have ever seen. A Central Machinery 6 inch Jointer. I bought it from Harbor Freight around 1985 for $98 delivered. I sold some toys I made at a flea market just before Christmas to get the money to buy it. It works great and has never given me one minutes trouble. However it's a heavy sucker. Right at 100lbs.
[quote]
Yes, I have one and it is quite heavy. I need help just to move it. I believe the shipping costs would be very expensive. It is a Wood Master 6" joiner.
[ATTACH]10506[/ATTACH]
[ATTACH]10507[/ATTACH]
[ATTACH]10508[/ATTACH]
[quote]
- 100_0021.JPG (65.85 KiB) Viewed 5545 times
- 100_0022.JPG (66.75 KiB) Viewed 5547 times
- 100_0023.JPG (66.19 KiB) Viewed 5540 times
I am sure removing the fence prior to 'lifting' would help!!:)
Shopsmith 6"jointer
yes I also have one of these that came from Harbor Freight
works great
works great
I've got a Woodmaster 6" jointer, band saw, belt sander, power stands, and 5 in 1. Got them all from a guy in CA back about 2000. He had a whole storage unit filled with stuff. the jointer is heavy and I leave it in place on the 5 in 1 most of the time. I haave the band saw set up on the power stand.
- fredsheldon
Has anyone ever developed a larger bandsaw for the SS. I find the 6" height limit restrictive at times when I'm cutting blocks out of logs. Or is there a mod to the existing model that would allow for more room heightwise. Or do I just bit the bullet and purchase a larger stand alone bandsaw.
Fred Sheldon
The Woodlands, Tx
The Woodlands, Tx
Considering that it has a cast aluminum base with ribbing, I think your last statement is most practical.
Orrrr you could stop playing with tree trunks!;)
- terrydowning
Look in CL for decent bandsaws with greater resaw capacity.fredsheldon wrote:Has anyone ever developed a larger bandsaw for the SS. I find the 6" height limit restrictive at times when I'm cutting blocks out of logs. Or is there a mod to the existing model that would allow for more room heightwise. Or do I just bit the bullet and purchase a larger stand alone bandsaw.
Terry
Public Photos of Projects
http://sdrv.ms/MaXNLX
Terry
