I Have a used 56 and wanted to use the disc sander. Speed dial was just ahead of low speed but when I turned it on it was running at atleast half speed. I turned the speed dial lower than slow, toward the high speed side of the speed dial plate, it slowed down at the fast speed setting. I realize now I probably shouldn't have gone in that direction. As I dialed past slow toward high speed the speed increased to half speed at the low speed setting with a rough sound but smoothed out as the speed went up.
My 85 Mark V doesn't act like that. Could the speed plate, slow to fast just be out of place? Or is it belts etc.
I know it sounds confusing
Speed at mid-range when dial is at slow speed
1985 Mark V, "2" Greenies, ShopSmith Bandsaw, jointer, belt sander. 14" Laguna bandsaw, craftsman 12" bandsaw, 12" DeWalt chopsaw,Delta 6" jointer, 12" Delta plainer, 16"-32" Performax sander, Shopsmith Jig Saw,
See if one of these PDF's help ya.
[ATTACH]10581[/ATTACH]
[ATTACH]10582[/ATTACH]
how to do a high speed adjustment.PDF- (382.25 KiB) Downloaded 641 times
how to reset the outside speed dial.PDF- (116.07 KiB) Downloaded 647 times
beeg wrote:See if one of these PDF's help ya.
Thanks Bob
I'll give that a try when I get back from a road trip DownEast on Wednesday. Where does the PDF info come from? I guess I should invest in some manuals, what would you suggest for maint. and repair literature?
Thanks for a quick response.
This PDF will get ya started with maint. and lubricating.
[ATTACH]10583[/ATTACH]
These PDF's come from either SS or an authorized SS repair service in Canada.
This site may help ya to.
http://www.shopsmith.com/ownersite/servicetips/index.htm
MKVMaintenance_1_10.pdf- (92.21 KiB) Downloaded 658 times
