Unknown Tool
truxton
Unknown Tool
Post by truxton »
This is a stanley hand tool with the sweet heart logo. Anyone here know what it is or what it was used for? Thanks[ATTACH]10587[/ATTACH]
stanley tool.jpg (45.28 KiB) Viewed 4445 times
Truxton
Michigan
Shopsmith MKVII, Power station, bandsaw, beltsander, Jointer, scroll saw, DC3300, Delta Unisaw, Mini-Max FS31 12" jointer/planer, Ridgid 12" miter saw, Porter Cable random orbit sander and bisquit jointer, Rockwell and Ryobi routers, Leigh dove tail jig, Husqvarna 257 chain saw, Paslode finish nailer
wa2crk
Post by wa2crk »
Some dimensions would be helpful. But it may be a tool for making symmetrical beads on a flat surface such as screen bead molding. Is there a number on it? Stanley usually has a number on their hand tools that can be looked up on some specialty web sites.
BillV
Gene Howe
Post by Gene Howe »
Looks like a lap siding spacer, to me.
Gene
dan1999
Post by dan1999 »
I think I have seen that tool a few years ago, it is a handheld tool for making mouldings circa 1910
Mark V 520,Mark V 510(2),Mark V 500(2) Dust Collector(2), Jointer(2), bandsaw(2), jigsaw, beltsander, biscuit joiner(2) Lathe Duplicator, RingMaster, Pro planer
truxton
Unknown Tool
Post by truxton »
Gene is right, I managed to get a copy of the USA Patent dated 09/07/1915, via my son and the internet. It is a clapboard sideing marker. After reading the patent I still am not clear as to how this was used exactly. It was interesting researching it, I knew someone here would know what it was. What can I say? I just love old tools, thanks for the replys. Truxton
Truxton
Michigan
navycop
Post by navycop »
It appers you would hold it by the handle. Then "rack" it down a board, thus making a pattern in the face of the board.
Mark V 520, Ryobi 12" mitersaw, Delta 10" tablesaw, DC 3300.
foxtrapper
Post by foxtrapper »
"The clapboard gauge is used in conjunction with a marker, such as this Stanley #88 clapboard siding marker which is used to scribe a line on the clapboard to coincide exactly with the edge of the corner casing against which it is to be fit. Because of the multiple points on the marker, a movement of less than an inch is required to scribe a line."
truxton
Unknown Tool
Post by truxton »
Thanks Foxtrapper, the picture appears to be the same tool. Now I can see how it's used. It has the adjustments to fit the angle and thickness of the siding. I imagine all you would have to do is just push it to mark the exact cut off line for an exact fit.
Truxton
Michigan
