It's Halloween - Show off your Frankensmith
damagi
Post by damagi »
Here is a thread for you to post photos of your frankensmiths. Does your Mark V shorty have a reversible motor? Does your Mark VII have 520 tables and rails? Whatever it is, lets see it =)
damagi AT gmail DOT com
damagi
Post by damagi »
I'll kick this off - here is my secondary shopsmith. Its a greenie, cut down to be a shorty. The table is off of a Mark VII with the trunions reversed.
I have a Mark VII motor that I may drop in this unit at some point. If I can find a cheap enough Base Assembly then I will attempt to convert this so that it will tilt both ways.
[ATTACH]10606[/ATTACH]
Mark V - Shorty Greenie with Mark VII Table.jpg (90.89 KiB) Viewed 1644 times
jy9394
Post by jy9394 »
This is number three- It's a dedicated drill press \ planer storage cart. I used the cut tubes from my shorty project (number two). Planer is also a great counter weight.
