Cleaning up the Bandsaw
deadbox
Post by deadbox »
Now to start on the bandsaw and finish off the list of parts I'll need. Here's what I've got to work with.
[ATTACH]11710[/ATTACH]
[ATTACH]11708[/ATTACH]
[ATTACH]11707[/ATTACH]
[ATTACH]11709[/ATTACH]
[ATTACH]11706[/ATTACH]
Some rust, lots of sawdust, and at least one screw missing. Those guide blocks worth trying to save? The blade looks pretty toast
1982 Mark V Model 500 - WIP http://www.shopsmith.net/forums/showthread.htm?t=7164
with Bandsaw - WIP http://www.shopsmith.net/forums/showthread.htm?t=7190
and Jointer, Belt Sander - Not started yet
8iowa
Post by 8iowa »
From what I see in the pictures the bandsaw's tires look pretty good. Clean them up with a nylon brush and some mineral spirits.
You have the old bronze back-up rollers. I would replace them with the new ball bearing types. You might as well get the cool blocks at the same time. The band saw will then run much quieter.
The new cover, with the tensioning window and dust port, is a little expensive, but nice to have.
Step 1 - release the tension on the blade! The red bar may already have been over-stressed.
Step 2 - You already know how to handle the rust. Judge the blade guides after rust removal.
Step 3 - I would get a upper blade guide upgrade(two bearings replace the one).
Clean, clean, clean. Once that crud is gone, clean the tires as already said. I use my finger nail to scrap the tires to remove anything embedded. An old credit card works too. I cut a lot of aluminum which embeds badly and must be removed soon after.
I would also discard that blade and start new. The blades are available most any where they handle bandsaw blades. Seventy two (72") inches is what you need.
I don't know for certain about the older bandsaw but the upper wheel bearing probably needs to be greased and I don't believe there is anything to be done to the lower bearing.
Please don't use it without a cover. I have never seen anyone who was mangled by a flying bandsaw band but I'll bet it is nasty.
deadbox
Post by deadbox »
I do have the bandsaw cover and its in perfect shape, just not in the pics. But no cleaning today. Its too damn cold outside (-20C / -4F) to scrub and soak in mineral spirits.
wa2crk
Post by wa2crk »
What is the item on the rear of the saw near the drive shaft? It looks like the retaining clip that is used to hold the lower wheel in position. Is it a home made cover retainer for a pully cover? Looks interesting whatever it is.
KDC
Post by KDC »
Nice bandsaw! I am doing the same as you I just bought an SS with a bandsaw for 200 clams. My blade did the same thing. I just tracked it while turning it by hand and made a easy adjustment. It worked when I went to look at it but I laid it down in the back of my truck and hauled it home (a 120 mile trek).
Where can I find the blade guide upgrades? I have a 1976 SS bandsaw. Is there any other upgrades for my bandsaw? Hope this wasn't a hijacking.
KDC
SS 1976 Mark V with SS bandsaw
beeg
Post by beeg »
Go here, then click on bandsaw on the left hand part of the screen.
http://www.shopsmith.com/ownersite/index.htm
deadbox
Post by deadbox »
wa2crk wrote:What is the item on the rear of the saw near the drive shaft? It looks like the retaining clip that is used to hold the lower wheel in position. Is it a home made cover retainer for a pully cover? Looks interesting whatever it is.
I have a pulley cover that seems to fit on that clip. Not sure if the cover is home made or not, but doesn't seem to be. I'll have a pic of it later when everything is reassembled
KDC
Post by KDC »
beeg wrote:Go here, then click on bandsaw on the left hand part of the screen.
Thanks, man. ;)
KDC
