Dust Collection in Table Saw Mode
I finally got around to hooking my dust collector to the SS table saw setup. There are two 2 1/2" ports on the lower saw guards. They don't seem to be very effective. I still get a lot of sawdust everywhere. Is this a common issue, or am I missing something? I'm using a 3/4 hp Delta two stage dust collector.
search the threads
Somewhere on here is a LONG thread regarding this very topic. Maybe one of the guys involved in that can link you to it quickly. I remember they worked on baffling under the table, etc. and made a very efficient system.
I believe that thread was Dusty's quest to reduce dust from his 520. I believe that John is working with the newer style 500 lower guard with the two ports. My recollection of that system is that it was far from perfect. I think the system on the 510/520 is an improvement but it still 'leaks'. ]fiatben wrote:Somewhere on here is a LONG thread regarding this very topic. Maybe one of the guys involved in that can link you to it quickly. I remember they worked on baffling under the table, etc. and made a very efficient system.
Rob in San Diego
- wannabewoodworker
Speaking of dust collection does anyone have the jointer dust port on their jointer??? I don't have it and the jointer really makes quite a mess when i use it. i was thinking of ordering the dust port for my jointer but if others have it and it doesn't work very well like the saw dust collection than I will just live with the mess.
Michael Mayo
Senior IT Support Engineer
Soft Designs Inc.
albiemanmike@gmail.com
1960's SS Mark VII, 1954 Greenie, 1983 Mark V, Jointer, Bandsaw, Jigsaw, Dewalt Slider, Delta Super 10, Delta 8" Grinder, Craftsman compressor, Drill Doctor, Kreg PH Jig, Bosch Jigsaw, Craftsman Router and Table...........and adding more all the time....
Soft Designs Inc.
I have the jointer dust port and it works well. IF I let the space under the infeed table fill up with chips.
Yes - IF I let the space under the infeed table fill up with chips - does it work better or not at all?beeg wrote:I have the jointer dust port and it works well. IF I let the space under the infeed table fill up with chips.
wannabewoodworker: I find that it works fine but you must connect the dust collector to it. Something that I often do not do.
It works less efficiently on heavier cuttings.
This was done on a 510/520 but the principle is the same.
https://forum.shopsmith.com/viewtopic.php?t=6063&highlight=collector
I suggest that you set your tablesaw up and blow all the sawdust off then rip several pieces of scrap and look for where the unwanted sawdust collects. Sit down on a bucket stool at study where it "must be coming from".
The dust collector when mated with the table has a lot of holes (leaks). I find that most of these are there to facilitate the reconfiguration process when changing modes. If you setup in the table saw mode, you can make the Mark V dust collection system near perfect. But then when you change modes, you may find that what you have done interferes with reconfiguration.
http://www.youtube.com/dustywoodworker#p/u/3/qO97xhst6wA
I am working on a dual hose system but haven't gotten far enough along to discuss details. I really miss the fabrication shop that I had access to when I was working. An ideal turned into prototype over night with those guys.
dusty wrote:Yes - IF I let the space under the infeed table fill up with chips - does it work better or not at all?
It works much better.
My 500 uses the dual port collection gadget. It's better than "nuttin", but it's far from complete. It's also a pain when changing blades and functions.
It appears that an overhead guard/collector would help. I tossed the SS guard many moons ago.
Anyhow, a well placed plastic tub from Walmart keeps most of the dust off the floor.
BTW, This remote is a real "turn on".
http://www.amazon.com/s/ref=bl_sr_electronics?_encoding=UTF8&node=172282&field-brandtextbin=SuperSwitch
Gene
Gene, if you still have that guard (the one that you tossed) let me know. I am experimenting with some modifications to improve the efficiency of the Shopsmith dust collection system.Gene Howe wrote:My 500 uses the dual port collection gadget. It's better than "nuttin", but it's far from complete. It's also a pain when changing blades and functions.
It appears that an overhead guard/collector would help. I tossed the SS guard many moons ago.![]()
Anyhow, a well placed plastic tub from Walmart keeps most of the dust off the floor.![]()
BTW, This remote is a real "turn on".http://www.amazon.com/s/ref=bl_sr_electronics?_encoding=UTF8&node=172282&field-brandtextbin=SuperSwitch
I have improved the system to the point where I can report the system collects over 95% of the dust generated when ripping. Cross cutting is another matter.
If I need to tilt the table - I also have some shortcomings yet to eliminate.
