Possibility of Mark V under table routing
gmlieb
Post by gmlieb »
I am trying to figure out a way that I can convert my Mark V to be able to do under table routing.
As far as I can see all that I would need is the ability to tilt it the other way like the Mark 7 has.
Any ideas or concerns.
Thanks for the help.
jcraigie
Post by jcraigie »
You can buy the mark 7 upgrade kit. That is one of the purposes of it, to allow undertable routing.
1984 Mark V 500 and an early 1954 greenie. jointer, belt sander, bandsaw, jigsaw, planner.
Jeff
gmlieb wrote:I am trying to figure out a way that I can convert my Mark V to be able to do under table routing.
1) remove way tube tie bar.
2) remove headstock.
3) remove table carriage
4) mount headstock reversed(quill to left/open end).
5) mount table carriage(normal orientation)
6) reattach tie rod
7) tighten locks and raise to vertical.
The headstock will be under the table with the quill facing up.;)
Be mindful of cutter rotation direction and feed direction.
P.S. Table 'controls' and motor switch will be on opposite sides.
algale
Post by algale »
[quote="JPG40504"]1) remove way tube tie bar.
6) reattach tie rod
The headstock will be under the table with the quill facing up.]
Dang it! Now I have to find another used shopsmith and set it up this way so I can do under table routing and shaping!
damagi
Post by damagi »
JPG40504 wrote: Be mindful of cutter rotation direction and feed direction.
Thats a pretty important one...don't want to be running a router bit in the wrong direction.
damagi AT gmail DOT com
damagi wrote:Thats a pretty important one...don't want to be running a router bit in the wrong direction.
I agree! Perhaps I was too subtle! I did not want to resurrect the 'climb' cutting discussion.
I mentioned it because the Mark5/V will be running the opposite direction as a Mark VII/7. Therefore the feed direction is reversed from Mark VII/7 instructions.
Location of the fence is VERY relevant also!
gilamonster
Post by gilamonster »
or, just buy the Speed Increaser.
without it, does the Shopsmith run fast enough for smooth routing anyway?
DOUG in PINE
My Dad's 1956 Greenie upgraded with Bandsaw, Jigsaw, Belt Sander, SpeedIncreaser, 1-1/8hp Emerson motor and 510 tables.
gilamonster wrote:or, just buy the Speed Increaser.
People were doing so a long time before the 'speed increaser' was created.
Since then the hand held router craze and later table mounted routers have arrived.
Yes the slower speed requires slower feed rates, but it will get the job done.
Lotsa 'router stuff now is actually shaping anyway.
SDSSmith
Post by SDSSmith »
For standard router bits, there is no issue with the standard Mark V headstock turning a router bit mounted on the quill in the wrong direction. The quill shaft rotates counterclockwise as do standard routers (looking at the end of the bit/shaft). The issue is feed direction (always a consideration with routers) and feed rate. The configuration as jpg describes is akin to a standard router table. The fence position would be behind the bit as it would on a standard table, feeding right to left in front of the bit. The feed rate would be 'very slow'.
Rob in San Diego
