Using a Mark VII Table top on my ER
Shop_Smith_Poppi
Post by Shop_Smith_Poppi »
Ok I have the table from my former now stolen Mark VII. I thought how cool I can put that on my ER and have a second table or even make a router table out of it.
Then the Ideal had a set back
Which I am sure most of you reading this will know already that the mounting tubes are not only larger in Diameter but set wider apart. :o
So I looked at it and said ok it will still work all I have to do is get some tubes that fit a ER and then dog leg them. Where they will fit into the mount on my ER. Problem solved now I have to find the tubing and figure out how to bend it using the Muffler Shop Bender machine!;)
Being as it is a lot smaller than 1 1/2 " OD I will have to figure out a sleeves to fit it and the shoes on the Machine.:cool:
Ok now it your turn do you think this will work?
If not what am I not seeing here.
Oh yeah Then Ihave to make a shim for the table top mounting bracket. You thought I forgot about that problem huh. :p
"Jerry! how many times do I have to tell you! Lick that knife before you put it back in the butter!" ..... Jerry Clower's Mother.
The original 10E had solid 1" round bar, not tube.
I would not attempt to bend this stuff.
I would make a flat bar to accept the 1" at the 10ER spacing, and a similar provision for 1 1/4" tubes going to the trunion at their proper spacing.
1 bar, 4 'tube' bores, 4(8?) tapped set screw holes.
Any difference in trunion pivot to tube/post dimension could also be allowed for by offsetting the two sets of bores.
peterm
Post by peterm »
Here is how I made a set of offset tubes for my jigsaw mounting:
[ATTACH]13165[/ATTACH]
You could likely use hardwood or plastic instead of brass and do the turning on a Shopsmith.
jigsaw eccentric tube components (2).jpg (118.84 KiB) Viewed 1004 times
Peter
