table saw guards instructions
- jcraigie
I have "acquired" one of the "new" clear plastic style table saw guards for the 500, but it doesn't have the mounting instructions. Does anyone have the instructions to show me how to mount it?
1984 Mark V 500 and an early 1954 greenie. jointer, belt sander, bandsaw, jigsaw, planner.
Jeff
Jeff
There is a decent exploded view here...
http://www.shopsmith.com/ownersite/part ... xpview.htm ,
and a nicer-yet finished view here:
http://www.shopsmith.com/ownersite/part ... ew_500.htm .
Part no. 188 Mounting Block is the main thing to attach to the table's tie-bar. I think the cap-screws no. 190 are 1/4-20 thread, so you need the corresponding tap and a no. 7 drill bit. If you look closely at the diagrams and play around with the Mounting Block, you'll see they fit together in one particular way, which you can use to center-punch the screw hole start locations.
Good luck!
Good luck!
Chris
Two pictures, the first shows the holesin the tie bar for that portion of the guard:[ATTACH]13272[/ATTACH]jcraigie wrote:I think I understand but If anyone that has one could take a picture of the mounting area for visual reference I'd really appreciate it.
The second shows the holesfor the upper guard:
[ATTACH]13273[/ATTACH]
Hope this helps.
- guard 1.jpg (153.76 KiB) Viewed 1824 times
- guard 2.jpg (100.21 KiB) Viewed 1824 times
Rob in San Diego
