Weight of the DIY upgrade ?
- camerio
- Location: Valcartier, just north of Quebec City, CANADA
For those of you who did the DIY upgrade to the powerpro, do you remember the size and weight of the parcel you received from Shopsmith ?
Camerio
MarkV 520 & Band saw
paulmcohen
I think it was about 70 lbs, and the size of a small hammock. FexEx delivered it to my door and the only really heavy part is the DVR motor.
Paul Cohen
Beaverton, OR
Beaverton, OR
I just measured the box that my DIY Power Pro came in. It is 15 1/2" x 15 1/2" x 16"h.
When delivered the box weighed about 70 lbs. The FEDEX driver is a little whisp of a gal who insisted that she carry the box. I didn't let her carry it very far.
My Power Pro motor weighed 17 lbs more than the A/C motor that it replaced. If you are also planning to do the double tilt upgrade, the quick disconnect lift assist is an accessory well worth considering.
- wlhayesmfs
When I was at the demo at Lowes the other day it was really neat using the assist lift since I have never seen it work. Only two fingers and up it came. At 45 degrees it went the rest of the way by itself. He showed me the quick disconnect for the double tilt and was very easy to take off and back one. I cannot afford the PowerPro right now but the assist lift and double tilt upgrade are on my radar real soon.
Bill
Broken Arrow OK
Broken Arrow OK
