Workbenches again
robinson46176
Workbenches again
Post by robinson46176 »
I mentioned on another thread recently (have lost track of that one now) about how I should maybe build a new workbench but my old tired one is like an old friend. I was in the local library about Friday and checked out among others "The Workbench Book" by Scott Landis. I'm still absorbing it... Worth the read.
As I read it and study each opinion and how the different guys work I think that I will hang on to my old bench for a while and just make some modifications and additions to it. I have a number of ideas. I am fairly well pleased with it in general. I originally made it around 1978 from stuff I had on hand. The top is 3 wide planks of very old very hard 2" yellow pine and the rest of the frame was just common dimension lumber. I would post a picture of it but that would take a day or two just to get back to it and uncover it. :D
As I was looking at it (from a distance :) ) I decided that I will just make a few changes and give the frame a nice coat of paint to cover all of the splotches etc. for now. I will also clean down and refinish the top which only had a wash coat of shellac. That will make me feel like I have a new bench in the new shop. I'll get some before and after pictures of it, I promise. :)
Feel free to post a picture of your bench in this thread and possibly a few lines about your thought process in deciding what you wanted in a bench...
In my case I work backward to most people. I like my main vise on the right end (most others put it on the wrong end :) ). I wanted a rail along the floor where I could put a foot up on it and shift my weight as I work. I drilled holes in the top and then put a strip under them so I can use short pieces of 3/4" oak dowel for bench dogs. I also have several through holes for using the standard old fashioned "hold-fasts" toward the left end is one of those little dogs that you raise by turning a little thumb-screw. At times I clamp one of those (dang, I can't remember the name now, starts with a Z?) vises at the left end.
wa2crk
Post by wa2crk »
Hi;
I will try to post a couple of my workbench that is from a set of plans from Woodsmith shop TV show. This thing really weighs a ton and has twice the surface of the old Sjobergs workbench. The top of the bench is 4 layers of MDF and the base is dimensional southern yellow pine lumber which I had on hand. The bench is about 8' from end to end and I have since added a router table to one end which extends the table to just under 10'
The top is as dead flat as I could make it. A 4' level does not rock from end to end when put on the top so it makes for a nice assembly table for long projects.
[ATTACH]14875[/ATTACH]
[ATTACH]14876[/ATTACH]
I added two quick adjusting woodworkers vices thatI got from Harbor Freight for half the price of new ones from Woodcraft or Rocklers. It aint fancy but it serves my purposes.
new and old bench.jpg (82.51 KiB) Viewed 735 times
workbench and router table.jpg (78.33 KiB) Viewed 732 times
