In search of a good light for lathe
mbcabinetmaker
I am trying to find a light like the on on my Powermatic band saw.
[ATTACH]14998[/ATTACH]
It takes standard type bulbs. Something with either a magnetic or clamp on base would be great.
- 1791216K_main.jpg (21.23 KiB) Viewed 2529 times
Mark
2017 Power Pro Mark 7
Mark
I recently found one at Kroger for $5 that has a crappy clamp, but a good goose neck with a 3/8" pipe threaded nipple and metal shield. Pitched the crappy clamp and used a metal L bracket to mount it.
Goose neck had a flexible plastic covering that was there I am sure to impress the distaff clientele, but inside is a real honest to goodness metal gooseneck.
It also has a line cord switch.
They come in different colors!!!!:D
So you may find one in an unexpected place(furniture department?;)).
You could go with the Shopsmith’s slip-on Utility Light I like it because no matter how long it is on, it is still cool to touch,
Joe
Being a VETERAN is an honor
Being a GRANDPA is priceless
Something like this?
http://www.woodcraft.com/Product/2004273/8816/MultiLamp.aspx
- jcraigie
Peachtree has a nice one http://www.ptreeusa.com/drillPress_Acc.htm scroll to the bottom of the page.
1984 Mark V 500 and an early 1954 greenie. jointer, belt sander, bandsaw, jigsaw, planner.
Jeff
Jeff
mbcabinetmaker
I made it by my local Woodcraft today and dropped $120.00 on two lights. The magnetic base is a nice heavy unit and the magnifying light was on sale. Now I can see!:)
[ATTACH]15092[/ATTACH]
[ATTACH]15091[/ATTACH]
- P1060154.jpg (257.09 KiB) Viewed 2471 times
- P1060160.jpg (239.82 KiB) Viewed 2470 times
Mark
Mark
- cincinnati
worknhard wrote:I use a Delta gooseneck lamp with a magnetic base... works great and easy to move around.
[ATTACH]15024[/ATTACH]
The Shopsmith lamp is good. I like the little brackets that can be attached to things a magnet won't stick to like aluminum or MDF etc...
The Delta lamp shown here takes a full size bulb and can be had at Lowe's (Tool department) for around $20 to $25 each.
"Prove to all the world Metal rules the land"
-Judas Priest, Heavy Duty.
I also like the shopsmith lamp. In fact I have adapted two of them to sit on the top of two (separate) floor lamp stands. Mine may not be beautiful but are great for use with many different tools, especially the lathe. I can twist that goose neck to shine light exactly where I want a flood of light. Fjimp
F. Jim Parks
Lakewood, Colorado:)
