Anyone ever put a sanding belt on a bandsaw? You have to remove the guides. Here is a company that sells them. Of course they don't sell a 72" belt. I read where someone made belts out of a roll of sanding cloth and JB Weld.
http://www.carterproducts.com/product.a ... &cat_id=81
Bandsaw sanding belt?
artfuldodger
My other band saw is designed to use sanding belts and came with all the parts needed to swap. I did that for a while but when I got a strip sander I simply started using that. Gee it must be 30 years or more ago, bet I'd have to look for the instructions to do the change over now... and I'm sure the belts are going to fall apart, no way the glue will have lasted this long.
I found this company that supplies various size belts at a good price:
http://customsandingbelts.com/abrasive.asp
[ATTACH]15624[/ATTACH]
- custombandsawbelt.png (23.74 KiB) Viewed 2552 times
Jim
510 upgraded to 520, bandsaw, Homecraft jointer, universal lathe rest, Craftsman tablesaw w/Delta fence, standalone belt/disc sander, power miter saw, a bunch of smaller stuff
Question remains: How well will they work on a shopsmith band saw with a canted and non-crowned wheels.
artfuldodger
I believe so.artfuldodger wrote:Thanks for the custom belt link. This might be better to do on a regular band saw. Do they have crowned wheels? At least with a long belt it would last longer but if you tore it you would have just wasted a long belt.
