little help needed.
farley
little help needed.
Post by farley »
need some suggestions as to what tool to use to remove a small around of wood in a tight spot.
I am making a LED clock, and I sanded out a cut out for the leds to hide BEFORE gluing up the back piece.
When the clock came, the bezel and clock were thicker than I thought, now the leds are hitting the bezel, so I have to carve out a little more towards the back.
the sanding wheel on my dremel won't work too well as I don't want to hit the back of the clock, and the clock insert is block frontage work
I don't think I can use a chisel as it's a rounded area.
I was thinking of some kinda burring tool for my dremel, most of those seem to be for metal, haven't tried it yet, thought I would ask you all first.
I drew a line on the picture the area I believe I need to remove.
TIA
jcraigie
Post by jcraigie »
theres a dremel bit that is almost like a tiny saw blade that I have used for situations like this I don't remember what it was called but I got it at Lowes
1984 Mark V 500 and an early 1954 greenie. jointer, belt sander, bandsaw, jigsaw, planner.
Jeff
2bits
Post by 2bits »
One of those ocillating cutters with a small blade may work. If you do not have one, let me know. I just got one of the P.C. brand and, depending on the size of the work area, I may have a small enough blade. I would have to look to see just how small it is.
kalynzoo
Post by kalynzoo »
Indeed, Dremel has a little rotary saw blade that you could use to trace most of the line. Do practice a few times on some waste wood, as the blade is very thin, unshielded, and can easily wander off line. Don't cut all the way to the corners. Xacto has a chisel blade that can be used to square the corners.
I like to do intrasa, and very fine accurate cuts are not unusual. Personally I would stay away from the Dremel. Great tool for giving texture but hard to control when making a cut. I would stick to the Xacto tools. First scoring the line, then carving/whitling away the waste material. I would finish with the Xacto chisel to smooth out the cut. Patients is the best helper in creating a clean finish.
Good luck and enjoy.
Gary Kalyn
Kalynzoo Productions
Woodworking
Porter Ranch/Northridge
Los Angeles, CA
trainguytom
What did they do before Dremels?
Post by trainguytom »
This, to me, really looks like a job for a sharp chisel. Use the chisel to define the lines as you go down, & work away at the stuff in between.
My dad's 1951 10er, 2 more 10er's, same vintage, a Goldie MK5, a 510 shortie with 34inch tubes, bandsaw, jointer, jigsaw, belt sander, a ton of small SS goodies and still looking...you just can't have enough Shopsmith stuff
farley
Post by farley »
thanks all and thanks 2bits for the offer.
I picked up a cutter for my dremel. It looks like a small barrel with fins all around it, smaller then my dremel sand drum. Tested it out and it seems good and controllable--unlike my past experience with a cutting wheel, which likes to walk.
will post final pix this weekend.
