Another original Mark VII feature I forgot
robinson46176
Post by robinson46176 »
I was sorting some tools and stuff in the old shop today (yes, I am still moving) and was standing petting my Mark VII while planning its move. I was puttering with it and studying the fence when I noticed the miter gauge lock. In earlier discussions of the Mark VII I had forgotten the miter gauge lock. It has a cam lock instead of tightening a knob. The cam lock uses a "U" shaped lock that you can flip down with your thumbs assuming that you have worked carefully and have thumbs. :rolleyes:
The fence of course also uses a cam lock. It has a rather long lever on it that "feels" good to me.
I am looking forward to getting it moved and lubed and putting it to work. Back when I bought it I had a lot of other stuff going on and had mostly just shoved it back in a corner since I didn't really need it and only used it a little.
robinson46176
robinson46176 wrote:I was sorting some tools and stuff in the old shop today (yes, I am still moving) and was standing petting my Mark VII while planning its move. I was puttering with it and studying the fence when I noticed the miter gauge lock. In earlier discussions of the Mark VII I had forgotten the miter gauge lock. It has a cam lock instead of tightening a knob. The cam lock uses a "U" shaped lock that you can flip down with your thumbs assuming that you have worked carefully and have thumbs. :rolleyes:
I was in the old shop this evening and grabbed the Mark VII miter gauge and brought it to the house to take a couple of pictures.
This one is with the cam locked.
[ATTACH]16016[/ATTACH]
This one is with the cam unlocked.
[ATTACH]16017[/ATTACH]
This is a shot of the bottom. Does anyone know the story of the holes in the outer end of the bar? It is not reversible...
[ATTACH]16018[/ATTACH]
As you can see I have not cleaned the Mark VII up yet. When I picked the miter gauge up after the last picture the screw at the heel fell out. I thought it must have been loose but it looks like somebody stuck in one that is too short to tighten. I think I have a few new ones in my parts cabinet.
I should have grabbed the fence too and taken a picture of it.
Mark VII miter gauge locked.JPG (73.92 KiB) Viewed 853 times
Mark VII miter gauge unlocked.JPG (85.4 KiB) Viewed 849 times
Mark VII miter gauge from bottom.JPG (75.42 KiB) Viewed 851 times
jayp413
Post by jayp413 »
This was one of the small details I always admired about my mark V11. Just another thing that sets it apart!
That countersink hole in the end makes it easy to hang on a pegboard hook.
However I do not recall of a reason for it and the tapped hole.
