Cutting Board Project
mrhart
Post by mrhart »
My oldest daughter wanted a cutting board, but something a little different with a natural look.
I found this piece of walnut at the local wood supplier. It was awesome to use the planer really for the first time-with newly sharpened knives :) . The horizontal bore I thought would be very precise and simple, but I did notice that the pressure put on the board, and where, will make a difference as well as a little table slop on the 54 greenie.
[ATTACH]16211[/ATTACH]
[ATTACH]16212[/ATTACH]
[ATTACH]16213[/ATTACH]
[ATTACH]16214[/ATTACH]
Walnut Cutting Board 2-10-12 01.jpg (90.75 KiB) Viewed 2468 times
Walnut Cutting Board 2-10-12 02.jpg (100.62 KiB) Viewed 2468 times
Walnut Cutting Board 2-10-12 14.jpg (104.26 KiB) Viewed 2467 times
Walnut Cutting Board 2-10-12 15.jpg (107.44 KiB) Viewed 2467 times
R Hart
holsgo
Post by holsgo »
Now that's a nice piece of wood.
Gene Howe
Post by Gene Howe »
Now, that's pretty cool.
Gene
jcraigie
Post by jcraigie »
Now That's a nice cutting board.
1984 Mark V 500 and an early 1954 greenie. jointer, belt sander, bandsaw, jigsaw, planner.
Jeff
jc24fan
Post by jc24fan »
Nice!!!!!!!!!! What did you use to treat the wood with? Also, do you thing red cedar would hold up for a cutting board?
mrhart
Post by mrhart »
jc24fan wrote:Nice!!!!!!!!!! What did you use to treat the wood with? Also, do you thing red cedar would hold up for a cutting board?
I just used an oil finish from Lowes, can't recall the brand as I'm not at home. It was for salad bowls ect on the label. A local spoon maker just uses mineral oil from wall greens. I looked on the label I have but it was too vauge to tell if thats all it was.
I am fairly new to woodworking, but from what I understand cedar would be too soft. Hardwoods are what I was told.
R Hart
beeg
Post by beeg »
jc24fan wrote: Also, do you thing red cedar would hold up for a cutting board?
It's to soft to use for that application.
fiatben
Neat idea
Post by fiatben »
I don't think I would ever have thought about a natural edge cutting board. That is so cool. I can see that, especially with bookmatched grain. Very unique and very simple, two things I really like in any project.
It looks very nice, and you did an excellent job, but did you accommodate expansion across the ends?
mrhart
Post by mrhart »
No sir I guess I did not. I glued and doweled between the slabs and the ends.
I have a cutting board that was made for my wife 16 years ago that has warped or cupped up on the ends. I had seen a table being built on the woodwrights shop, and putting the end pieces on the table with dowels or pins would prevent that. I didn't think about expansion at the ends.
I need to make another one...suggestions please.
R Hart
