Belt Sander bummer
seiferre
Belt Sander bummer
Post by seiferre »
I'm trying to install a new sanding belt, but the tensioner appears to work in reverse. It will not lock, keeping tension on the belt. It returns to the "install new belt" or slack position each time I turn the unit on. I can't see any broken parts in the unit. Any help appreciated. Thanks
seiferre wrote:I'm trying to install a new sanding belt, but the tensioner appears to work in reverse. It will not lock, keeping tension on the belt. It returns to the "install new belt" or slack position each time I turn the unit on. I can't see any broken parts in the unit. Any help appreciated. Thanks
View the Sawdust Sessions. There is one on cleaning and inspecting the belt sander that I believe will put you back in business.
seiferre
Bandsaw Bummer
Post by seiferre »
Thank you Dusty. The sawdust article was most helpfull, and the belt sander is working correctly now. Now; to tackle the bandsaw.
