Pix of some shop enhancements
Gene Howe
Post by Gene Howe »
These first two are my redneck "Big Gulp" dust shroud for the SCMS. A Dollar store storage tub, a toilet flange and some scrap wood.
[attach]16444[/attach]
[attach]16445[/attach]
This is my re-purposed treadmill. A BIG sander. Takes a 105X15 belt.
[attach]16446[/attach]
Gene
derekdarling
Sander
Post by derekdarling »
Nice sander, Gene! Have you thought about mounting a variable-height roller above it? Could be a great thickness sander! Makes me a little more willing to pick up a used treadmill. Hmmmm, I wonder where I can hide that?:D
Derek Darling
Surrey, B.C. Canada
10ERs, other stuff, you know.
Gene Howe
Post by Gene Howe »
I have, Derek!
I'm pondering how to do it so it's accurate and easily adjustable. I also need to make up a stop that I can move along the length and remove when using it as a thickness sander. The stop is easy. The roller apparatus...not so much.
Treadmills aren't all that easy to hide.;)
derekdarling wrote:Nice sander, Gene! Have you thought about mounting a variable-height roller above it? Could be a great thickness sander! Makes me a little more willing to pick up a used treadmill. Hmmmm, I wonder where I can hide that?:D
Gene
wannabewoodworker
Post by wannabewoodworker »
How about using a second treadmill mounted above the treadmill you currently have but turned 180 deg. so that it runs in the opposite direction. Just a thought and it would probably require some serious welding to make it work but used treadmills are pretty easy to find cheaply on CL.
Michael Mayo
Senior IT Support Engineer
Soft Designs Inc.
albiemanmike@gmail.com
1960's SS Mark VII, 1954 Greenie, 1983 Mark V, Jointer, Bandsaw, Jigsaw, Dewalt Slider, Delta Super 10, Delta 8" Grinder, Craftsman compressor, Drill Doctor, Kreg PH Jig, Bosch Jigsaw, Craftsman Router and Table...........and adding more all the time....:D
derekdarling
Sander
I'm thinking using a big piece of UHMW under the belt as it is inherently slippery, and many holes for heat dissipation. I'll give the roller idea some thought. I have a line on a treadmill locally (Vancouver, B.C.), so we'll see. Like you said, these are hard to hide!
I am starting to make instruments, and something like this would be ideal to thickness sand wood for acoustic instruments. Cool idea!
Derek
Derek Darling
Surrey, B.C. Canada
jm51
Post by jm51 »
Within a week of your wife mentioning a desire to get fit, loving husband (you) presents her with a treadmill. Once 3 months pass without her using it, ask if you can have it for the shop. :)
derekdarling
jm51 wrote:Within a week of your wife mentioning a desire to get fit, loving husband (you) presents her with a treadmill. Once 3 months pass without her using it, ask if you can have it for the shop. :)
Brilliant! Points for thinking of her, and extra points for putting the thing to actual use. I think it'd go better with flowers, things generally do!
'I'm pulling for you; remember, we're all in this together' ... Red Green
Derek Darling
Surrey, B.C. Canada
