DLB wrote
. Years ago I went to the Miter-Pro, also from SS, this was way before the MiterSet was offered. It works well within its limitations, meaning four-sided objects.
Over the years I have been enlisted by my artist wife to build picture frames for her pieces. About ten or fifteen years ago she asked me to do a run of about 30 identical frames. I knew it was going to be a really difficult task, so I decided to go for the Miter Pro. And it worked great. I am currently doing another run of 12 identical frames for her and the Miter Pro is making it an easy job. So, while I really like the Miter Pro, it can't do what the Miter Set does and I think the Miter Set is a completely different animal. Once the Miter Pro has been set up, as long as the proper sequence of cuts is followed, a right angle corner is guaranteed. The Miter Set, though, isn't a jig that will hold the workpiece during cutting. It will give you the perfect angle for whatever you want to build, but it won't hold that angle through the cut like the Miter Pro will.
Maybe what would help with cutting segments would be not just a longer fence but a longer fence that is also equipped with some vertical hold downs to clamp the segments in place. So what I am imagining is an L-shaped sled attached to the face of the miter gauge. After setting the miter gauge with the Miter Set, the workpiece would be snugged up to the fence and clamped down to the sled for the cut. Sorry no picture, but hope this is clear.
Maybe somebody who knows his way around Sketch-up might be able to draw it.
