Bob T,
If this helps, the standard single belt for the Model 10E and 10ER is 4L380. That's a 38" "V" belt and works with the 1/2 HP A. O. Smith motor common to Model 10's. Some motors may require a different size belt and most commonly a 39" belt (4L390) which is sometimes needed for a 3/4 HP motor. I also use a 39" belt for additional speeds besides the listed 3 speeds of the Model 10's to give a total of 7 speeds. See the attached chart for more information.
_
Table of Speeds Model 10s.pdf
If normally using a 39" belt than add a 40" (4L400) belt for the additional speeds.
For anyone using the Speed Changer the belt sizes are 4L220 and 4L250 or 22" and 25". The original belts for the Speed Changer were 22.5" and 25.5" but those 1/2" size belts (4L225 & 4L255) are no longer found.
