Shopsmith turning comfort
Hydraulics are 'firmer'.burkhome wrote:Or maybe Pneumatics. Ought to be some sort of Pneumatic piston available that could be rigged to fit SS.
The Jack-Bench design looks to be pretty solid and you can pick a couple of scissor jacks at a junk yard pretty cheap.keakap wrote:A voice in mah haid is screaming "hydraulics!"
Ever watch a house be lifted? Dozen or so hydraulic jacks placed strategically (funny how that word looks some like "tragically") and connected to 1 source pump. Flip a switch.
'Course with the Mark V all you'd need is one jack per end, tucked away in the inside of the new legs...
Jack
Just occured to me-- check the yaller pages, see if there's a Gurneys `R Us shop in your area. Maybe they be havin a sale on last year's models. Or howbot "used"-- check the local undertakers'!dusty wrote:Raise or Lower the Shopsmith to position it where you are comfortable.
Adjustable Legs??? How to build adjustable legs - that is the question.
A friend was building a model steam locomotive and found a hospital bed mechanism to build it on. The engine weighed nearly 1000 lb. but he could crank it up and down:
[ATTACH]21205[/ATTACH]
You could crank your Shopsmith to whatever level is comfortable!
- IMG_1505 Hudson 17Aug06.JPG (82.57 KiB) Viewed 2238 times
Peter
- terrydowning
I've seen these before and always though they might make for a relatively simple solution for changing the SS height.
http://www.harborfreight.com/1000-lb-capacity-motorcycle-lift-68892-8495.html
Too expensive for my taste to experiment with as I don't seem to have the discomfort issue with either the lathe or the tale saw. At least not enough to make major modifications.
The hospital bed mechanism looks interesting as well.
Terry
Public Photos of Projects
http://sdrv.ms/MaXNLX
Terry
- robinson46176
keakap wrote: Or howbot "used"-- check the local undertakers'!
They tell me that can be a cheap source for good used dentures too...
You don't want to rest anything long term on the lifting device, so you would need a second set of solid legs or risers. Even that motorcycle lift, the bottle jack will slowly leak down if you don't have anything locking it out.
If it were me, I would build simple risers under the legs and an electric chain hoist with a spreader and furnitire straps to life the machine without damaging it. Keeps floor space clear and I'm sure you could find other uses for it.
