A question for you Other early vintage 10E Owners
everettdavis
Re: A question for you Other early vintage 10E Owners
Post by everettdavis »
Another curious production change that I noticed occurred between the release of the Preliminary Manual (which I am in the process of restoring now) and the first 10E Owner's Guide they promised to release soon, within it.
The 10E's had a User Supplied Plywood Extension Table and a "Y" Mounting base for it.
Among the earliest MAGNA Shopsmiths produced were different than those soon after which had a production change occur even before the first Owner's Guide was released.
It was a change where part number 104-2 Tailstock Square Stud, was changed adding a 2nd threaded stud, washer and wing-nut just like the one above, and the knob 104-6 was replaced with a wing-nut.
Refer to the two part illustrations below.
I do know that it was still present on my 10E sn 1414 as illustrated.
I wonder how many 10E's produced after 1414 still had the Square Stud, and at what point it changed.
Everett
Tailstock Mount Change.png (655.62 KiB) Viewed 3243 times
10E Tailstock from SN 1414 with Square Locating Pin 104-2.jpg (145.35 KiB) Viewed 3243 times
oldiron
Post by oldiron »
My #6834 has the plywood base and two round studs.
10 E nubbin etc..jpg (294.55 KiB) Viewed 3217 times
SN 3779 has two studs and wingnuts and plywood aux table.
SN E-1750 has only one "nubbin" on the headstock. It came to me with an upgrade 10ER tailstock and aux table installed, but the originals were still in the goody box. Two threaded studs and a wingnut on this one.
In other news, while checking on these parts, I discovered that the goody box also contained a "very rare 10E original table raiser". It was disassembled, and I had no idea what the parts were for until I recalled and found that post. Thanks, guys! Not bad for a $140 machine that also included a speed changer! :)
everettdavis
It is hard to find. I have seen only a handful.
If you ever decide to part with the early table raiser, I would love to have first crack at it. I will of course be willing to offer more than the $3.95 original price.
The appeal of the newer design that replaced it was that the majority of the mechanism was removed with the table, opposed to being installed on the carriage.
Everett
Original 10E Table Raiser Mechansism - small.png (411.2 KiB) Viewed 3188 times
everettdavis wrote:It is hard to find. I have seen only a handful.
Everett
I have only seen maybe three. The one I have Buckeye's and maybe one other on eBay. They all had the straight sided main body casting. Has anyone seen the angled body casting pictured in the manual?
everettdavis
To my knowledge, all of the ones I have seen are like yours. I have not seen one like depicted in the manual for them, yet.
I saw one in Houston, one in Denver, and one in Oklahoma City that I can recall through the years. None were being offered for sale as they were on or with the owners machines.
The one in Houston had the lower pulley belt guard that attached to the motor mount plate, and it had the lower blade guard. It was the first time I had seen either of those too in person.
Everett
Everett
I'll probably hang on to it Everett. My 10ER came with a complete/intact jointer setup, so I have a good start on a pretty complete museum piece. I've also seen a couple of original SPT adapters and once even a lower saw guard lurking in CL goody boxes nearby, but someone else got to them before I could. If I change my mind for some reason, you will most certainly get first dibs on the table raiser.
everettdavis
Thank you sir. You are most kind.
Everett
Around here, I suspect I am more a museum piece than any of my Shopsmiths! They have worked for decades, don't require much maintenance, and keep on working...
