Quill Advance Trouble Shooting
cmn135
Re: Quill Advance Trouble Shooting
Post by cmn135 »
I used a silver paint marker to show where the opening for the keyhole slot because it’s hard to see it once you hook it with a pick and try to slide it over the knob.
Sent from my iPhone using Tapatalk
br549
Post by br549 »
Glad you got it working.
I have never taken my quill return apart, so was anxious to see the parts you described.
Thanks to rpd for downloading and posting your first picture and for the YouTube video... I decided to download and post your second picture.
In the future, if you could, it is much better to post pictures directly on the Shopsmith forum website. Years from now your third party hosting service may not exist and pictures may not be available. Shopsmith's posting methods and requirements are a little hard to follow at times, but if you keep image size 2050 pixels (or less) in width, AND 1180 pixels (or less) in width, AND total file size of 2 MB (or less), all should be fine. You can attach up to 10 pictures per post.
cmn135
Post by cmn135 »
I use the Tapatalk app for forum browsing on my iPhone. I thought when i uploaded directly to a thread using this method it did upload directly to the website. I will try to do as you request next time.
beeg
Post by beeg »
Since ya have the quill out, clean and wax the hole it goes into and the outside of the quill.
pdeardorff
Post by pdeardorff »
Thanks for this subject. The spring on my Mark V let loose. Once I pulled the quill and the advance mechanism I was able to see that the spring simply slipped off. I will now try to tap the "rivet" or pin down since I seem to have the same issue of reattaching the spring and it slips off as I start my reassembly.
Keep up the good work!
Phil
