Glue to attach Planer Stainless Steel Clad to Aluminum Casting
GetterDone
Re: Glue to attach Planer Stainless Steel Clad to Aluminum Casting
Post by GetterDone »
JPG wrote: Sun Sep 22, 2024 12:54 pm Missed that! :o
Wonder how the new piece will be formed over the ends. If not very strong adhesion is required.
Me thinks I would replace it with a sheet of hdpe(slick)
That a great Idea. :D
I have yet to check the condition of the one I acquired about a month ago. :)
Dwayne
GetterDone wrote: Sun Sep 22, 2024 5:25 pm
If it ain't broke, don't fix it! ;)
GetterDone
JPG wrote: Mon Sep 23, 2024 10:01 am
For sure. :) I bought a bunch of stuff with it and did not even look at . :eek:
I hope it is okay. :D
Dwayne
edma194
Post by edma194 »
HDPE would be a great surface for the planer bed. Very slippery. But also very difficult to glue it to the aluminum casting ;)
Actually silicone would work very well to hold it down. It can be thinned to spread a light coat. If it can be wrapped over the ends of the casting it could be held down with screws there. If it gets scratched up it will be easy to peel off with the aid of some solvent.
edma194 wrote: Mon Sep 23, 2024 1:39 pm HDPE would be a great surface for the planer bed. Very slippery. But also very difficult to glue it to the aluminum casting ;)
I guess that no planer manufacturer's do this it is not a great solution.
jsburger wrote: Mon Sep 23, 2024 7:54 pm
It may be too 'non-rigid". Oughta feed easy though.
clemensk
Post by clemensk »
I finally finished this task. I used the 77 glue. Tacky enough and still easy to position. I did 3d print a press due to bend the aluminum sheet. It looks okay. But I have the feeling the aluminum table itself is not 100% even. But it’s minimal and I don’t think it will hinder me to create plane enough boards.
Matanuska
Post by Matanuska »
Looks nice, but wondering why it would be necessary to do this. Not possible to clean, polish, and wax the aluminum table to achieve a low friction surface?
- Matanuska
1984 Mark V upgraded to 520 PowerPro. Shopsmith cast iron table bandsaw, jointer, belt sander, and 60's vintage 610 jigsaw SPT's. Makita 2040 15" planer, JessEm Mast-R-Lift II router table.
Matanuska wrote: Tue Oct 22, 2024 6:13 pm Looks nice, but wondering why it would be necessary to do this. Not possible to clean, polish, and wax the aluminum table to achieve a low friction surface?
Because that is the way the OEM aluminum table on the MK mount planer was constructed. The non MK mount Pro Planer has a cast iron table. To save weight the MK mount planer has an aluminum table and is skinned with stainless steel for durability.
Matanuska
Post by Matanuska »
I wasn’t aware the MK version had a SS skin. I wonder what happened to the original skin that required a replacement.
- Matanuska
