Restoration of Mark V / produced on 11/84
HopefulSSer
Re: Restoration of Mark V / produced on 11/84
Post by HopefulSSer »
GetterDone wrote: Tue Sep 17, 2024 6:52 pm
I may have Overlooked or just do not have the other Dovetail piece that goes on the guard itself.
Thanks for the pictures. :)
I was wondering what that big guard was I have at least one of those. ;)
It's this
Greenie SN 362819 (upgraded to 520), Bandsaw 106878, Jointer SS16466
GetterDone
Post by GetterDone »
HopefulSSer wrote: Tue Sep 17, 2024 8:26 pm
It's this
Yes Thanks. :)
I just found one of mine.
Most of the Extra stuff was in totes from every purchase. :D
Not complaining at all.
I may find a few more now that I know what I am looking for. :cool: :cool:
Dwayne
GetterDone
A little Progress.
Final Cleaning pictures coming soon. :)
Cleaned the headstock out and will be looking to get a Sticker.
I know there are older threads about the (Disappearing sticker) :D
This is some good Cleaner IMHO / Better than 409 :cool:
I have a lady that owns a Print company.
I have also noticed that some Members have made these labels.
My big Question is ??
I have a 1981 model /Then Qty 3 1984 models.
As long as there is a sticker on there for the (Not Knowing) this Speed control Knob issue.
Which year needs /Which Page # on the sticker?
Dwayne
This is a reference for which page the warning is on in different Owner's Guide editions. Although the copyright didn't change for 7th through 13th editions their release date did. The 7th edition is from April 1957 while the 13th edition is from January 1973. Somewhat irrelevant since they all have the warning on page 2. The release dates for the different editions are shown in blue. Do know that some of the serial numbers, shown in red, are guesstimates as to when they were made. The 8th, 10th and 12th editions are missing from the list but should be Page 2 as I believe some later Owner's Guides would be. Check the Owner's Guide you have for your Mark 5/V to see which page the CAUTION label should reference. That separate CAUTION was no longer used on the "C" Headstock.
Caution Label page number by manual edition (Greenie’s & Goldie’s directly on headstock, Gray on backing sticker)
Manual Copyright 1954 1st Edition Cat. No. EM – 9100 - M5 - 3:54 Page 4 S/N through 272923
Manual Copyright 1954 2nd Edition Cat. No. EM – 9100 - M5 - 7-54 Page 6 S/N 272924 - 293882
Manual Copyright 1954 3rd Edition Cat. No. EM – 9100 - M5 - 4/55 Page 6 S/N 293883 - 301454
Manual Copyright 1954 4th Edition Cat. No. EM 9100-A-M5-8-55 Page 6 S/N 301455 - 312507
Manual Copyright 1955 5th Edition Cat. No. EM 9100-10:55 Page 6 S/N 312508 - 332849
Manual Copyright 1955 6th Edition Cat. No. EM 9100-A--10:56 Page 6 S/N 332850 - 342419
Manual Copyright 1957 7th Edition Cat. No. EM 9100-B 4:57 Page 2 S/N 342420 -
Manual Copyright 1957 9th Edition Cat. No. EM 9100-C 3/59 Page 2 S/N 355761 -
Manual Copyright 1957 11th Edition Cat. No. EM 9100-C 1/62 Page 2 S/N 373834 -
Manual Copyright 1957 13th Edition Bulletin No. 504286 1/73 Page 2 S/N SS1001 -
All SPT's & 2 Power Stations
GetterDone
chapmanruss wrote: Thu Sep 19, 2024 1:12 pm This is a reference for which page the warning is on in different Owner's Guide editions. Although the copyright didn't change for 7th through 13th editions their release date did. The 7th edition is from April 1957 while the 13th edition is from January 1973. Somewhat irrelevant since they all have the warning on page 2. The release dates for the different editions are shown in blue. Do know that some of the serial numbers, shown in red, are guesstimates as to when they were made. The 8th, 10th and 12th editions are missing from the list but should be Page 2 as I believe some later Owner's Guides would be. Check the Owner's Guide you have for your Mark 5/V to see which page the CAUTION label should reference. That separate CAUTION was no longer used on the "C" Headstock.
Thanks for the info.
The only owner's manual I have does not reference this.
The duplicator manual mentions it and says Page 2.
So, I am going with page 2. :)
Dwayne
GetterDone
Okay I have made a decision to paint the bare cast inside with a light gray engine paint.
Maybe that will help with the cleaning in the future.
Dwayne
GetterDone
Before removing the roll pin in the tilt base, I noticed that the pin was flared. :eek:
I drilled the back side of the base to have access to the rear of the pin.
This pin was Stuck :rolleyes:
So I drilled the end of the pin till it separated at both ends,
I will replace the pin with a new one.
Dwayne
GetterDone
I just received a New to me attachment tonight.
A Shopsmith friend of mine shipped this to me over the weekend.
I got a great deal on it an extra literature of other stuff as a Plus.
As I unboxed the Strip sander,
I noticed the same thing that there was not a lot of Deburring of flashing on the cast parts from the factory. :)
I deburred the bottom of the strip sanding table and painted it the same color I painted the inside of this 1984 headstock.
It is in pretty good shape. :)
Does this slot have a Purpose?
After reading this label?
Is there an Upgrade for the strip sander?
This is it after the paint job.
The casting has a circular place like the Band saw / ??. :)
Dwayne
You are fortunate to have the metal idler pulleys. Take good care of them.
If you may need to use it with the internal sanding belt arrangement, I recommend you get one of the current plastic pulleys since then one pulley face bears against the abrasive side of the belt.
As for that mystery slot - Only the shadow knows. I do not.
Hopefully some of the literature you received includes a copy of the Strip Sander Manual. Yours is currently set up for internal sanding having the one Idler Wheel below the top Tracking Wheel instead of its normal position at the back near the same level as the lower Idler Wheel.
