Mobility kit
mbcabinetmaker
Mobility kit
Post by mbcabinetmaker »
A while back I posted about a better way to move my 510 from the shop to the trailer to the job sight etc. I wanted a simple fix that would also work with my other Shopsmith. This is what I came up with.
[ATTACH]16745[/ATTACH]
[ATTACH]16746[/ATTACH]
I made a simple axle from 5/8 round bar and attached wheels with stop collars. I mounted some small rope hooks onto the legs of the 510. By lifting the machine one end at a time the rope hooks just set over the axle. Very easy to set up and break down.
[ATTACH]16748[/ATTACH]
Now while the system worked pretty well by just manhandling the light end of the 510 I had a thought about using the moving handle that came with my Mini Max CU300 Smart.
[ATTACH]16749[/ATTACH]
It required a slight modification to one of the axles.
[ATTACH]16750[/ATTACH]
Now the handle just slips into the knotch.
Mark
2017 Power Pro Mark 7
mbcabinetmaker
[ATTACH]16751[/ATTACH]
And by lifting the handle it picks the front wheels up and I can make tight turns with ease.
Mark
You Go Mark!!!!!!!!!:cool:
mrhart
Post by mrhart »
Nicely done sir. Some reflectors and a lic plate, and you could discard the trailor. :rolleyes:
R Hart
mountainbreeze
Post by mountainbreeze »
If you can somehow figure out a way to connect the powerhead to the axle, you could ride that thing around the shop! :D (You'll need a long extension cord though).
Bill
Mark V 520 50th Anniversary Edition, Planer, Jointer, Bandsaw
mountainbreeze wrote:If you can somehow figure out a way to connect the powerhead to the axle, you could ride that thing around the shop! :D (You'll need a long extension cord though).
No he did not do all that so you could 'borrow' it!:D
