bandsaw blade speed
onevw
bandsaw blade speed
Post by onevw »
I have a power pro and need to know what blade speed is a the low RPM of 250 set on the power pro head. I need to cut some metal.
onevw wrote:I have a power pro and need to know what blade speed is a the low RPM of 250 set on the power pro head. I need to cut some metal.
Say what?
Doesn't the PowerPro already know all those speed settings?
pennview
Post by pennview »
About 720 feet per minute.
Pi (3.14) time the diameter (11 inches) times 250 = 8635 divided by 12 = 719.58
Art in Western Pennsylvania
onevw
Post by onevw »
I was not aware the power pro head computer gave me the blade speed of the band in the bandsaw. So i go and look
Thanks
onevw
Post by onevw »
pennview wrote:About 720 feet per minute.
OK Then it looks like a speed reducer is in order to get me blade speed down to a low of 100 FPM
Thanks
RICK
pennview
Post by pennview »
Take a look at this thread for an alternative to the speed reducer -- https://forum.shopsmith.com/viewtopic.php?t=7758
onevw wrote:I was not aware the power pro head computer gave me the blade speed of the band in the bandsaw. So i go and look
Thanks
It doesn't. But it does set rpm according to the type of work you are setting up for.
Sorry for the sarcasm. It must be a bit of jealousy (and poor character).
onevw
Post by onevw »
Can the speed reducer be mounted on the left side of the power head the side opposite the sliding quell??
peterm
Post by peterm »
Yes:
[ATTACH]19984[/ATTACH]
I saved this from another post but no recollection from who. Maybe the search function might find it. I seem to recall Nick Engler explained how.
EDIT: when all else fails.....check the Owners Manual: pg18/19 in Speed Reducer Manual shows how. You swap the drive hub and the white plastic female connector(called a "special coupler") on the speed reducer.
Peter
