help with new belt
mjmadrid114
help with new belt
Post by mjmadrid114 »
hello,
my name is Mike and I just got a Shopsmith from my next door neighbor and I am having a problem with adjusting the speed control.
The tool was vary dirty and need to be cleaned... After a good cleaning i am having a hard time getting the speed control right. I was running when I got the ShopSmith but the speed control was not working right now I have it working but when I start the the ShopSmith up it pops the breaker. The manual has nothing on it. I called the help line and they had me take the belt off and it did not pop the breaker. I know I am not stetting it right.... is there anybody out there that can help me out with this. mmadrid31@ymail.com or call575-3-4416
thank you for your time
beeg
Post by beeg »
Welcome to the forum Mike. Have ya read this thread yet? https://forum.shopsmith.com/viewtopic.php?t=7092
Have ya oiled the sheaves yet?
joshh
Post by joshh »
Some folks have reported popping breakers if the shopsmith is started with the speed set above slow. I'll bet if we solve your speed control problems and get the machine oiled well, your breaker popping will stop.
What happens when you try to change speeds?
Also, do not change speeds unless the shafts are rotating (either by hand or under power).
- 1986 Mark V 500 Mini
- 1985 Mark V 510 with reversible motor, bandsaw, jointer, and double-tilt.
I offer quality motor reversal, rebuilding, and rewiring. Contact me at HarbourTools@live.com
