Power Station Question
triumph_tech
Post by triumph_tech »
I just came home with a SS Bandsaw that was attached to a Power Station. I appears to be in very good condition and runs well but the speed control lever on the Power Station seems to be missing something. It will not lock the speed and as the unit runs the speed lever moves around on it's own. I don't have a manual for it or a parts diagram. It would seem there is a washer or spacer missing from behind the lever. Any body have a power station they can snap a photo of or a parts diagram?
It might be more fruitful if you posted a picture of what you have.
BUT...never fear. We can resolve this issue.
[ATTACH]23989[/ATTACH]
[ATTACH]23990[/ATTACH]
It is a friction lock.
Power Station Speed Lock 001 (Custom).JPG (66.57 KiB) Viewed 2418 times
Power Station Speed Lock 002 (Custom).JPG (68.78 KiB) Viewed 2416 times
triumph_tech
Looks like the shaft is much farther out, it moves in and out at least a 1/4".
triumph_tech wrote:Looks like the shaft is much farther out, it moves in and out at least a 1/4".
In your posted image, you can see a "c" clip that prevents the shaft from going into the Power Station Casting. There should be one similar, if not identical" on the inside of the casting on that square shaft. I suspect that clip is missing. If there it would prevent the shaft from coming outward.
If it is missing, you should be able to find a replacement at Ace or any other hardware store that handles piece parts.
triumph_tech
Didn't find a c-clip but did find allen screw and washer that was backed out almost 1/2" on the other end of the same shaft. A drop of loctite and a 5/32 allen wrench and I'm back in business. Thanks! Not too bad , a power station and a bandsaw for $100.
triumph_tech wrote:Didn't find a c-clip but did find allen screw and washer that was backed out almost 1/2" on the other end of the same shaft. A drop of loctite and a 5/32 allen wrench and I'm back in business. Thanks! Not too bad , a power station and a bandsaw for $100.
Not bad at all. The motor on the Power Station is worth almost that much.
BTW: that motor, unlike the Mark V motor, needs to be oiled periodically.
triumph_tech
Is there a speed chart for the Power Station? I know it doesn't run as fast as the the MkV does but how do I know what speed for what tool? Other than the planer are there other tools that don't work well with the Power Station?
judaspre1982
power station speed settings
Post by judaspre1982 »
power station speed settings 001.jpg (122.44 KiB) Viewed 2394 times
power station speed settings 002.jpg (126.42 KiB) Viewed 2387 times
power station speed settings 003.jpg (123.94 KiB) Viewed 2387 times
power station speed settings 004.jpg (136.2 KiB) Viewed 2391 times
power station speed settings 005.jpg (127.3 KiB) Viewed 2385 times
judaspre1982
more
power station speed settings 006.jpg (128.35 KiB) Viewed 2380 times
power station speed settings 007.jpg (133.15 KiB) Viewed 2377 times
triumph_tech
Yep, that's what I needed, Thanks again!
