IPM-1 Jointech
dgreen810
IPM-1 Jointech
Post by dgreen810 »
Does anyone on this forum use the IPM-1 by Jointech fence for your table saw fence on a MK 5. If so what is your opinion? I have been using mine as a router fence, even used it with my drill press and radial arm saw.
I have the old original Incra Jig I use as well on occasion on my free standing drill press.
Don G
Gene Howe
Post by Gene Howe »
Don't know if it's an I-PM. Mine's the one they built for the Shopsmith MKV.
I use it as the TS fence and router fence. It's a great piece of equipment.
Once the rails were attached, no other fence will work. And, without those rails, it can't be used any where else.
Gene
dgreen810
Post by dgreen810 »
If you go to my site at http://www.picturetrail.com/smoke810 and look at the Tormek album, the picture showing all the carving knives, they are on the router table with the IPM-1 (Incremental positioning machine) on the right of the router insert.
edit: I just moved two more photos in the same album at the bottom of the list,
Don G
Gene Howe
Post by Gene Howe »
Don,
Here's a picture of what I have. Except mine is a 500.
Not the same as yours. Sorry.
[ATTACH]24279[/ATTACH]
A jointechshopsmith.jpg (10.48 KiB) Viewed 8434 times
Gene
ecom1
Re: IPM-1 Jointech
Post by ecom1 »
dgreen810 wrote:Does anyone on this forum use the IPM-1 by Jointech fence for your table saw fence on a MK 5. If so what is your opinion? I have been using mine as a router fence, even used it with my drill press and radial arm saw.
Don G
Hey Don, I just PM'd you regarding this thread.
Shopsmith: 2 Mark V 510 (1988,1993), bandsaw, jointer, mounted planer, belt sander, scroll saw, strip sander, lathe duplicator, conical disc sander, biscuit joiner, free standing router table with Jointech IPM-1
Other stuff: Bosch glide mitre, Ridgid 13" planer, Rikon drill press, routers, drills, and other toys
