Bandsaw Table - How to enlarge?
milo_the_lumbarbarian
Post by milo_the_lumbarbarian »
Has anyone successfully enlarged the size of your Bandsaw table? Have you replaced it with a homemade one, covered your current table with an insert type arrangements, or added to your current table?
Any advice is always appreciated, as are links!
Thanks!
Milo
beeg
Re: Bandsaw Table - How to enlarge?
Post by beeg »
WHICH BS table are you asking about? IF the cast iron, here's one way.
http://www.shopsmith.com/ownersite/cata ... system.htm
Check out how Nick Engler used the main and extension tables to effectively create a huge bandsaw table:
[youtube]https://www.youtube.com/watch?v=3y95p0wXwM4[/youtube]
algale
Post by algale »
This owner did a major mod to his table, replacing it first with wood and then with metal plate. http://www.crenshawweb.com/texastele/ttp04.htm
masonsailor2
Post by masonsailor2 »
I found the table on the band saw is not really adequate for my needs. Its too small and doesn't offer enough versatility in jigging and clamping. This is my solution. Works really well and is rock stable for resawing.
Paul
Here is a thread that shows how I expand the table size on my bandsaw.
http://www.shopsmith.com/ss_forum/viewtopic.php?t=13405
If you have a shopsmith with the ability to do so you can create a pretty big work area with out much effort.
I apologize for the delay thanking everyone for your kind replies. Had a health issue pop up that slowed me down. I look forward to reviewing all these great replies and asking more questions. Thank you, everyone!
Oh yes, I have the aluminum table on my bandsaw.
