I am acquainted with a master maker named Josh Kinsey. You can find his work on Facebook at
https://www.facebook.com/jwkinseysartifice
and at his webpage
http://www.jwkinseysartifice.com/
The purpose of my post is not to to promote his work he sells but for the jigs and tools he makes to make his art pieces. Some of them are incredible works in their own right.
Master Maker
Steamdragon
Re: Master Maker
For lack of a proper term, it's amazing what a true visionary can see in his minds eye and the talents to produce these visions. I've spent nearly a half hour on his site and now feel like a speck of dust on his floor. Thanks for posting this. There are some fine talented folks on this forum too and we're fortunate to have them share their wisdom with us.
Re: Master Maker
Interesting!!!! An index 'drum'.
Steamdragon
Re: Master Maker
These are some pictures of a boring guide he built.
- 11949466_907644972643932_3456472571614441120_n.jpg (63.72 KiB) Viewed 2744 times
- 11949314_907644989310597_6166913422839622069_n.jpg (59.98 KiB) Viewed 2744 times
- ChrisNeilan
Re: Master Maker
The above photo is called a steady rest. Used to keep spindles or bowls "steady" as you hollow (or drill) them out. Many on the market for $300 and up. A home made one does the job for a lot less. I mainly turn wood, so this has been on my wish list for a while.
Steamdragon
Re: Master Maker
The wheels are from a set of roller blades.
Re: Master Maker
Or possibly scooter wheels, Lee Valley sells them for that purpose. Polyurethane WheelsSteamdragon wrote:The wheels are from a set of roller blades.
I should imagine they would also be available from you local bike shop.
Re: Master Maker
David J. Marks is another truly unbelievable wood worker.
http://www.djmarks.com/
Some of you might remember the show he had on PBS years ago called Woodworks. He built a steady rest that is almost identical to the one above.
