Kreg Bandsaw Fence
- ChrisNeilan
Kreg Bandsaw Fence
So, I have figured out with your help, where I went wrong with the Kreg bandsaw fence. Now, a question... WTF is this set screw for? It's definitely in my way!
It is on the far left of the bandsaw table.
- Set screw.jpg (51.44 KiB) Viewed 1673 times
Re: Kreg Bandsaw Fence
It is the screw that provides a stop when the blade is 90 deg to the table. But you have to set it. It may be too long and if it is use a shorter one.
It is the stop screw that sets the table back to 90* after you have tilted it. It has a lock nut on the under side. When properly adjusted it sets the table to be 90* to the left and right of the blade. The lock nut keeps it from moving. That set screw will be below the table when properly adjusted.ChrisNeilan wrote:So, I have figured out with your help, where I went wrong with the Kreg bandsaw fence. Now, a question... WTF is this set screw for? It's definitely in my way!It is on the far left of the bandsaw table.
Maybe this "light reading" will help. Reference page 18.
http://www.shopsmith.com/ownersite/manuals/845539.pdf
- ChrisNeilan
Well, thank you! I bought this bandsaw on Ebay and thought i had worked the bugs out. This should be the last one. I usually use a squre to be sure i'm at 90 degrees. Don't trust them screws!
- ChrisNeilan
Thank you Dusty, my only bandsaw manual is for a cast iron bandsaw. Some slight differences i see.
It is not the screw that must be trusted! It is the one who set the screw and then the lock nut that you must learn to trust.ChrisNeilan wrote:Well, thank you! I bought this bandsaw on Ebay and thought i had worked the bugs out. This should be the last one. I usually use a squre to be sure i'm at 90 degrees. Don't trust them screws!
dusty wrote:It is not the screw that must be trusted! It is the one who set the screw and then the lock nut that you must learn to trust.ChrisNeilan wrote:Well, thank you! I bought this bandsaw on Ebay and thought i had worked the bugs out. This should be the last one. I usually use a squre to be sure i'm at 90 degrees. Don't trust them screws!
- ChrisNeilan
I don't trust him (me) either!dusty wrote:It is not the screw that must be trusted! It is the one who set the screw and then the lock nut that you must learn to trust.ChrisNeilan wrote:Well, thank you! I bought this bandsaw on Ebay and thought i had worked the bugs out. This should be the last one. I usually use a squre to be sure i'm at 90 degrees. Don't trust them screws!
Come on Man!!ChrisNeilan wrote:I don't trust him (me) either!dusty wrote:It is not the screw that must be trusted! It is the one who set the screw and then the lock nut that you must learn to trust.ChrisNeilan wrote:Well, thank you! I bought this bandsaw on Ebay and thought i had worked the bugs out. This should be the last one. I usually use a squre to be sure i'm at 90 degrees. Don't trust them screws!
