On sale and on my list but I'd like to know if it can be mounted(drilling and what not) while the shopsmith is in vertical position.
The one I have for a drill press is loaded up with SPT and is not easy to nor something I want to have to put in horizontal position. Yes it can be done if it really really had to.....
It is 500 with powerpro if that makes any difference. From the pictures it looks possible but I like to know for sure.
Anyone, anyone at all??
Gas Spring Table-Raiser, question??
Re: Gas Spring Table-Raiser, question??
I don't see why not. You can get to the screw positions for drilling with no problem. Just make sure you get the one for the Power Pro head stock since it is heavier.reible wrote:On sale and on my list but I'd like to know if it can be mounted(drilling and what not) while the shopsmith is in vertical position.
I am in the middle of hanging a new TV. When I get done I will take a picture and post it so you can see what it looks like in the vertical position.
This is the one for the table, ie drill press. There two versions, 500 and 510/520. However if you can get pictures of the attachments point on yours it would be helpful.
When you said Power Pro I was thinking of the lift assist that has the stronger cylinder not the table raiser.reible wrote:This is the one for the table, ie drill press. There two versions, 500 and 510/520. However if you can get pictures of the attachments point on yours it would be helpful.
Anyhow here is the picture. Mine is mounted slightly different because on my dedicated drill press the head stock and carriage are mounted on the way tubes 180° opposite of normal. The upper bracket is mounted on the carriage the same way. The lower bracket is a bit different but the screws are in the same surface of the pivot arm as the normal mount so there should be no problem.
If you take my lower bracket and turn it 180° in both directions and hang it over the edge of the pivot arm that would be the normal mounting position. The screws end up on the same surface as the way mine is mounted.
Confused yet?
The bottom line is that you should be able to install it just fine in the vertical position.
- 20170822_161122.jpg (324.87 KiB) Viewed 3896 times
Great! Thank you.jsburger wrote:When you said Power Pro I was thinking of the lift assist that has the stronger cylinder not the table raiser.reible wrote:This is the one for the table, ie drill press. There two versions, 500 and 510/520. However if you can get pictures of the attachments point on yours it would be helpful.
Confused yet?![]()
It is on order. No mention of back order so I should get it in short order.
